[email protected]
- Jan 1, 1970
- 0
| [email protected] (Michael Moroney) writes:
|>[email protected] writes:
|>>| One weird setup I've seen, and I'm not totally sure exactly what it is:
|>>| 1 large 3 phase transformer (single can) with a small transformer can
|>>| below it on a pole. The small transformer has NO MV connection nor even a
|>>| MV bushing! It sits below the drops to the homes/businesses. The only
|>>| thing I can think it could be is the big can is 240V delta, and the high
|>>| leg powers the small can, with is a 208V/240VCT. The big can powers half
|>>| the residential services plus any 3 phase services, the small can powers
|>>| the other residential services. It's sort of Scott-T relative to the big
|>>| can. But this is a guess, I actually don't know how it's wired. I even
|>>| took a photo to try and figure it out. There are quite a few of these
|>>| setups in Philadelphia.
|>>If the big can is already 3 phase, why would anyone need to also have a
|>>Scott-T? That doesn't make sense. It must be something else. How many
|>>MV bushings on each can?
|>3 on the big can, 0 (yes, zero) on the small can.
|>I called it Scott-T like because I'm guessing the small can is fed from
|>the 240 delta high leg to neutral, which would be 90 degrees shifted from
|>the 240VCT winding. Assuming my guess at what it is is correct at all.
|>> How many secondary lugs?
|>4 on the big can, I believe 4 on the small can.
| I looked at my photo again, and it is understandable what is going on
| after all. See for yourself:
| http://www.accvio.com/temp/two_cans.jpg
| http://www.accvio.com/temp/two_cans_large.jpg (full size)
| It's not clear the large transformer has 3 MV bushings, but it does.
| One connection from the large transformer goes only to the small one, 3
| others (1 connected to a bare neutral) go below it and two additional
| leads from the small can go downward, for a total of 5 leads that run down
| the pole.
| There's another (probably) 120/240V service going left to right (with a
| drop to the upper right) that's appears not to be involved or connected,
| except for the neutral.
| It appears to me, if the large can is delta with the lead to the small can
| the high leg, that this is a 5 wire 2 phase circuit, or what many would
| call 4 phase, 4 poles spaced at 90 degrees and a neutral. Can anyone
| suggest an alternate possibility?
It looks to me like what is going on is that the first can provides common
208Y/120 like:
A-----N
And then the second can turns one of the phases into 120/240 like:
A-----N-----A'
Most of the loading is 3 phase where 208Y/120 serves the need, but some
load needs genuine 240 or split phase 120/240 and they didn't want to
hang a 2nd can up high to do it directly from MV (and can't bring the
MV down to where the 2nd can is now).
Just a guess.
| the pole.
208Y/120 like:
A-----N
A-----N-----A'
Just a guess.
