Closed Delta 120/240V 3-phase service
K
krw
Currently, the area around Vancouver BC. Other residential areas with
single-phase service: near Waterloo, Toronto, and St. Catharines
Ontario, near Montreal Quebec.
Where do you live that has full three-phase MV on top of every pole on
every street in a residential area? And three transformers on every
pole that has a transformer?
The transformers aren't on every pole (every third), but the wires
are. I see it all over. All you have to do is look.
Not where I live now, nor where I've lived for decades. Again, where do
you live that has 3-phase on the pole outside every house?
Everywhere I've lived (some underground).
Don Kelly
krw said:
Where do you live, Mongolia? The only places I've seen single phase
distribution is in the middle of the country (rural Vermont, in
fact).
Your *guess* is wrong.
There are many places where a single phase is run down an alley (the next
alley is on another phase so that the total district load is pretty well
balanced across the 3 phases. This is true in residential districts in many
cities which exceed 1,000,000 inhabitants. Simply a matter of economics in
situations where high heating or, more likely, cooling electrical
demands are not present. Where I am, a 3 phase main feeder is across the
street but a single phase feed from this line serves the whole of a small
subdivision. There is simply no need for running 3 phases (particularly
underground) as loads don't warrant it in this case. In a previous home, 3
phase was down the alley but only because there was a commercial load at the
end of the street which warranted the 3 phase feeder.
There is no "one size fits all" solution so no BS is involved-just different
observations in different places.
K
krw
Even the purely residential area I grew up in had all three phases
on the pole (one pig per pole - four houses per pole).
Everywhere I've looked but *very* rural areas has three phase
distribution.
| In article <[email protected]>,
| [email protected] says...
|> > obviously very different practices on different sides of the pond.
|> > Virtually all residential distribution over here is 3 phase. The only
|> > time I've ever spotted single phase is when an isolated property has its
|> > own transformer.
|> I just wish I had three-phase into my house.
| Different issue. My father wanted three phase into his house in the
| late '50s. He argued that it was on top of the pole already so it
| was a simple matter to bring it down to the entrance panel. They
| told him that they would do it if he guaranteed a $100/month bill
| (rather steep for the '50s).
There is, afterall, a cost to keep 2 more pole pigs up there. Those things
are not cheap.
| In article <[email protected]>, [email protected] says...
|> >Look again (open your eyes this time). You're not seeing the forest
|> >for the trees. It *IS* on top of 90% of the poles in the country.
|> >The other 10% are single phase only, generally found only in rural
|> >areas.
|> Really?
| Really!
|> In all of the places I've lived, residential areas had
|> single-phase service only: a single MV line running down the top of the
|> poles along the street or alley, and single-phase transformers
|> providing center-tapped 120/240 service to several houses per
|> transformer.
| fact).
MV comes out of substations in three phase. The distribution trunks
are three phase. But many side branches, particularly residential
areas, are single phase MV. So everyone on the same street is on the
same phase. Big deal. The utility saves money doing that and can
keep things in balance by putting the next street on a different phase.
|> Three-phase distribution is used for large customers
|> only.
| Bullshit!
Of course in the distribution design, three phase goes all over the place
because there might be scattered need for three phase. And then they have
to keep it reasonably balanced where it does go, so the single phase lines
branching off or going to a direct service are balanced over these phases.
|> Given the amount of area covered by single-family houses
|> compared to the area used by commercial/industrial/large residential
|> (high rise), I'd have to guess that more than 50% of the total number
|> of poles that have any transformers carry one single-phase
|> transformer.
Actually this is quite common. Even if three phase distribution goes
through a residential area, the transformers on the poles for homes
along the way are usually just one transformer supplying one phase to
that bunch of homes.
|> >> transformer.
|> >fact).
There are lots of distribution lines with all three phases. There are
also lots with just one phase. Either way, just one transformer is the
norm for residential services.
|> >> transformer.
You manage to only live in strange places.
One house I lived in a long time ago had only single phase MV on it.
Another around the corner (after we moved) had three phase MV on it.
One pole pig served 3 homes single phase. The three phase then ran
on down the street and branched off to a school which had three very
large pole pigs. I went to grade school there and by 5th grade knew
that was for three phase power (but I didn't yet know the difference
between delta and wye).
Where I live now has a single phase MV branch running down about 6
poles and then goes underground to serve 3 pad mounts. It comes off
a three phase MV trunk that goes to a college about 4 miles north.
If I wanted three phase power here, it would be VERY expensive to get.
Dave Martindale
I *have* looked where I live. I've told you what I see (a single MV
wire on the top of the vast majority of poles in residential areas).
The next level up the distribution hierarchy is 3-phase, so 3-phase
lines do pass through residential areas, but only one phase is tapped
for the line of poles down each street or alley.
Again, where do you see 3-phase on every pole? Tell us some places.
Even when there are 3 phases, do the transformers occur in groups of 3?
Or do you mostly get one transformer per pole, tapping only one of the
3-phase MV lines? (That's what I see when there does happen to be
3-phase distribution).
And where would that be? City or suburbs?
K
krw
|> >> transformer.
|> >fact).
Good grief, Phil! Read! It's not distribution, rather service!
The three secondary phases *ARE* on the poles.
|> >> transformer.
Nope, Midwest, Northeast/New England, but I see it everywhere.
K
krw
|> > own transformer.
are not cheap.
Try reading Phil. The pigs were already there! Three-phase was
already available on the pole; only the drop and meter were needed.
K
krw
Afghanistan?
Illinois, New York, Vermont (haven't looked here in OH).
Sure.
One pig per pole, three wires going between poles, under the MV
lines.
<shrug> City (and state) not big enough to have suburbs.
| In article <[email protected]>, phil-news-
|> |> > own transformer.
|> are not cheap.
Try getting a handle on business and economics. The cost of _using_ the
equipment has to be paid for. There are costs of maintenance and replacing
things that break. If the transformer blows up, the utility replaces it.
If it is shared between two businesses, they share the costs. This is not
a freebie ... except for the base level of service required for residences.
|> |> >> transformer.
|> |> >fact).
|> |> >> transformer.
I've lived in some of these areas plus the south. I've never seen any kind
of three phase service besides wye (either 208Y/120 or 480Y/277 and in one
case 600Y/347) and delta (presumably 240D/120 since there was a center
tapped leg on the few I've seen) for three phase and split phase (240/120)
for single phase. I've also seen some 2-wire single phase feeding some
highway lighting, but I did not know the voltage (could be any of 120, 240,
277, 347, 480, 600 as far as I know).
You're sure none of these are in any abundance where you live?
| Afghanistan?
If I ever get there, I'll tell you what I see, if I make it back. But
I have read some descriptions that would suggest something like 380Y/220
for three phase.
Maybe you should. You'll find a LOT of 208Y/120, some 480Y/277 (larger
buildings), and maybe some leftover 240D/120, as well as single phase
service in 240/120. But do take your camera if you are convinced there
are some "6 star" services around.
| Sure.
And how many lugs on each are wired up? Does each transformer have the
same number of MV bushings (whether that be 1 each or 2 each)?
| lines.
That's single phase 240/120 of the Edison split phase variety. No three
phase services there.
Look for cases of THREE transformers, each with the same number of MV
bushings (either all have 1 or all have 2 each), and at least 3 LV lugs
connected on all three. If only 2 lugs are connected on all three, then
you have a wye system, usually 208Y/120 but 480Y/277 is possible (600Y/347
is very rare except in Canada). If 2 lugs are connected on 2 transformers
and 3 lugs are connected on one transformer, it is probably 240D/120.
Other possibilities also exist. Be sure to get a number of photos at many
different angles to get an unambiguous view of exactly how all the wires
are connected. If you see one with 3 lugs connected on each of 3 separate
transformers, where the middle lugs of each are connected together, and
all the outer lugs, plus the joined middle lugs as one wire, supply 7 wires
into whatever building is served, then be sure to get a LOT of photos.
| Different utilities in different areas have different practices, including
| the willingness to bring three phase down a street that doesn't need it
| yet, or will never need it.
I can't rule that out. And maybe I've seen it, as I have seen many cases
of three phase MV on a residential street without noting whether it was
going through to somewhere else or if all three phases were used (such
as by three separate single phase taps). A few streets in town here have
two sets of three phase MV. I'm guessing some have special uses (like a
hospital circuit) or are feeding strictly to further distance circuits.
charles
yes, very useful. A few years ago, the phase from which our house was
supplied kept tripping out. I seemed to complain more than others, so the
house was swapped on to phase 2 (Yellow, White, or whatever).
|> > own transformer.
And someone else's house got swapped over to the bad phase.
K
krw
|> |> > own transformer.
|> are not cheap.
Phil, try getting a handle on reading comprehension; They're ALREADY
THERE!
K
krw
|> |> >> transformer.
|> |> >fact).
|> |> >> transformer.
In a residential neighborhood? Get real!
K
krw
| Afghanistan?
for three phase.
They surely wouldn't be called that because it's a stupid idea.
| Sure.
Never climbed a pole, but all three phases are used for Edison 240V
service. How may lugs is that?
| lines.
Bullshit! The three wires were the three phases. You could see the
connections on the pigs.
Exactly!
I'm not in the business of supplying your curiosity.
