Complementary amplifier Differential Measurements for duty cycle
Davewalker5
Sep 20, 2014
125
Using an O-scope to measure Differential Measurements on Two channels for Complementary amplifiers.
O-scope channel#1 is on the Positive cycle of the complementary amplifiers output
O-scope Channel#2 is on the Negative cycle of the complementary amplifier output
The input signal is not a sinewave, it's a square waveform
When measuring the On time and off time of the complementary pairs amplifiers output using square waveform, the Oscope is Ch1 - Ch2 differential measurement.
This will give the Duty Cycle?
Davewalker5
Sep 20, 2014
125
The Transistors used for the amplifier is 2N6295 and 2N6297
On the datasheets there is a parallel Diode
what is this diode for? the diode is reversed compared to the Emitter to base diode in the transistor , why is that
To balance the swing?
To Clamp the voltage and limit the current?
To Stabilize the output?
To Protect from reverse polarity or a short circuit?
Davewalker5
Sep 20, 2014
125
Here is the power transistors diode schematic
