Computer power supply question
Mopac76
Oct 29, 2021
I want to power two 24v 50watt halogen lamps from a computer ATX power supply that I have rewired to provide 24volts output. The power supply shows that the +12v circuit is rated at 20amps and the -12v circuit is 1amp. What is the maximum load across the 24v that I can use?
bertus
3,877
As the -12 Volts is only 1 Amp, you can have a max load of 1 Amp, so 24 Watts.
Bertus
Kiwi
Jan 28, 2013
506
You could try a DC voltage step up module from Aliexpress to boost the +12v to the required 24v for the bulbs.
dave9
Mar 5, 2017
1,191
^ Or just get a mains voltage to 24VDC adapter and do without the computer PSU instead of a second regulated stage which probably drops efficiency and adds bulk.
