Computer power supply tester; buy which one?
W
Whamspam
No problem with my computer. I just want to play.
Power Judge by PowMax:
http://www.amazon.com/Pin-ATX-Power-Supply-Tester/dp/B000CP4RRA
Or
CoolMax Power Supply tester:
http://www.amazon.com/Coolmax-24PIN-Power-Supply-Tester/dp/B000BKTESI
I can't find any instructions on the internet for using these things
effectively.
I was thinking about hooking one of these to an empty power socket with
everything else hooked up. Should be able to boot up and diddle with my
computer without any error signals popping up. Does that sound like a
strategy?
Lingering questions regarding quick pulses or dips in voltage, how high
or low or wide, whether these test devices will recognize quick
excursions outside the voltage limits and hold the error display...?
Maybe I'm getting too deep. If my [slow] DMM is happy, then should I be
satisfied?
-Neil-
Jeroni Paul
There is much more to test from a power supply than just its
electrical behaviour. It can have bad solder joints, weak capacitors
or intermittents, causing hangs only at long term. At full load may
fail to regulate properly or hold at all. Only long term usage in the
target system will tell if it works properly. Marginal supplies may
work better in some systems than others.
James Sweet
Or
effectively.
strategy?
satisfied?
-Neil-
They're all pretty worthless, just buy a multimeter. You can poke the
probes in the back of the ATX connector while the computer is running.
Michael A. Terrell
JW said:
Both are practically worthless; about as effective as a "check engine"
light on your car's dashboard. They won't test the power supply under load
conditions.
Really? A power supply tester is handy if you have to go through a
lot of power supplies. I have two other models that see a lot of use.
In fact, I used one a few days ago to show someone that their supply was
bad. Its true that a cheap tester won't find EVERY problem, that do
kick out a lot of the bad supplies faster than a voltmeter and jumper.
it also eliminates the motherboard's power control circuit and front
panel switch. i have seen plenty of bad switches, and a number of bad
motherboards that wouldn't turn the PS on.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Michael A. Terrell
Or
effectively.
strategy?
satisfied?
-Neil-
You disconnect the 20 or 24 pin cable from the PS at the motherboard
and connect it to the tester. It puts a load on the +5V supply, and
allows you to meter the voltages. I have never seen one made to be used
along with the motherboard.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
James Sweet
If you have 100 psus and need to do a quick check on them the tester
could have some value, but for what the OP requested, the tester will be
next to worthless. If you want to evaluate the condition of just one
or two psus, you have to do much more extensive testing.
Michael A. Terrell
James, I built test fixtures at the Microdyne factory to test power
supplies for their $20,000 to $80,000 telemetry receivers. We did a lot
of tests to EVERY one of the $700+ power supplies before they ever got
close to a radio. You have to know your test equipment, and when to use
what. Denying yourself some simple tools for quick tests is a stupid as
trying to work with no test equipment.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
W
w_tom
You have to know your test equipment, and when to use what. Denying
yourself some simple tools for quick tests is a stupid as trying to work with
no test equipment.
Which is exactly why one buys the multimeter and does not use a
'magic box' power supply tester. The former provided a definitive
answer and with numbers that can obtain further useful information.
The latter (power supply tester) hardly applies a load, does not
really say why it is 'go or nogo', and never really provides a
definitive answer. Get the meter because one needs simple tools for
quick and reliable tests. A tool that is also useful for solving
other electrical problems - not just the power supply.
Power supply tester will not even provide a definitive answer AND
makes useful assistance from others almost impossible (no numbers).
Michael A. Terrell
Yawn. Go troll somewhere else.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
W
w_tom
Michael must denigrate when he cannot technically justify what he
posts. Michael was a technician who wired boxes without knowing what
those boxes did. An informed lurker uses a meter as recommended by
many others; ignores a technician who must attack the messenger.
Why? He cannot technically defend his recommendation.
mark krawczuk
hmmmmmmm a MULTIMETER is gonna apply even LESS of a load than a power
supply tester.
basically computer power supplys work or they dont , all he . me want to
do is see if they work or not.
why wont the power supply tester work ?
mark krawczuk
multimeters put less load on than the computer power supply testers.
Or
effectively. I was thinking about hooking one of these to an empty power
socket with
strategy? Lingering questions regarding quick pulses or dips in voltage,
how high
satisfied? Thanks,
-Neil-
mark krawczuk
a MULTIMETER puts a LOT LESS LLOAD on than a power supply tester.
a multimeter will show the same results as the tester , wether there is
the corrct voltage or not....simple.
DaveM
No.. it's not that simple. A PS tester puts a minimum load on the main
regulated output of the PSU; just enough to allow the PSU to come up. All the
other outputs are totally unloaded. The tester only provides an "idiot light"
indication of the condition of the PSU, whereas a digital multimeter, even a
cheap one, will provide a qualitative indication of each of the PSU outputs...
and under actual loaded conditions (if the PSU is left connected in the PC).
With those measurements, you can make a much better determination of the
condition of the PSU. Who knows the voltage limits of the LED indicators on the
tester? Nobody specs that for their testers, at least for none of the testers
that I have seen on the net.
With a multimeter, you will know, with known accuracy (within the spec'ed
accuracy of the DMM), what the actual output voltages are. The tester won't
give you that info.
True, the DMM still doesn't give you the total picture, such as ripple and noise
on the outputs, but knowing the actual voltages on the outputs is an order of
magnitude better than what the "idiot lights" tell you.
Yes, it takes a bit more time to check each output individually with a DMM, but
it's a much better test. On second thought, it might even take less time to
check with a DMM, because you don't have to disconnect the PSU from the
motherboard, then hook up the tester, then turn on the PSU. With a DMM, you
only have to gain access to the PSU connector and touch the probes
appropriately.
As far as testing a pile of PSUs, I guess you can use a tester to cull out the
obviously dead ones rather quickly, but beyond that, I question its value.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
address)
Life is like a roll of toilet paper; the closer to the end, the faster it goes.
Michael A. Terrell
And?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
W
w_tom
Please read the procedure before posting. Standard procedure: never
disconnect and never remove anything until AFTER data is collected.
Disconnecting a power supply or using the power supply tester; both
are testing with virtually zero load - not informative and not
useful. And both do disconnecting. Meter in but two minutes does
best test because nothing is changed or removed. Best load is
motherboard and active peripherals. Best data is numbers; not a GO/
NOGO light. No numbers and no load from a power supply tester reports
little that is useful and provides no useful (and further) information
from newsgroups.
See DaveM post for further information. Get the meter to save time,
accurately repair the first time, and become informed as to why things
fail. Shotgunning or that power supply tester reports so little and
teaches nothing.
James Sweet
Yes, that's what the rest of the computer is for. As I said, poke the
probes into the *back* of the connector pins while the PSU is powering
the motherboard.
James Sweet
supply tester.
No they don't "just work or they don't". All kinds of things can go
wrong with power supplies. Output voltage can be too low or too high or
sag under load, there can be excess ripple, glitches, plenty of faults
only show up when heavily loaded. I just replaced an Antec power supply
recently that powered up fine and all voltages checked out ok, but the
outputs would gradually sag under load until the computer would just
randomly shut off. A PSU tester would have passed that one with flying
colors but it failed in service and using a multimeter while it was
operating the computer in question was the only way to diagnose it.
Michael A. Terrell
Yawn. Give it up Tommy boy. You have to spread lies about anyone
you disagree with. Why don't you just go back to and leave these good people alone? You never contribute anything
useful. You only copy & paste your views on surge protection, while
citing quotes from agencies that are long gone.
No matter what you say about me, makes no matter because you are
simply an anal retentive usenet kook and and love to start flame wars.
Tell me, do you have Google groups email you every time your name, or
surge protection is mentioned? The engineers on
have repeatedly driven your spew into the
ground, and all you can do to counter it is to copy & paste the same old
crap.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
