In <f23687cf-a62b-4424-a3b9-bc8988720084@h16g2000yqj.googlegroups.com>,
Actually it looks more like 3.1mm/year since 1993, after sitting at
1.8mm/year for the previous century
http://en.wikipedia.org/wiki/Sea_level_rise
It will still take a while to submerge the piers in New York, unless
the ice sliding off the Greenland and Antarctic ice sheets speeds up
any more - at the moment the GRACE satellites make them good for
0.55mm per year, but it isn't easy to understand what is actually
going on inside the ice sheets, though we can now directly measure the
total mass changes.
I expect sea level changes to be mere millimeters per year until we get
enough warming to actually do major damage to Greenland's ice sheet.
I suspect that the upward bounce that I expect after 2030-2035 or so to
about 2070 or so to fall short of accomplishing such. It appears to me
that global surface temperature as high as 3 degrees C above 1951-1980
or 1961-1990 average may not do only minor damage to Greenland's and
Antarctica's ice sheets.
What I see being the problem is if we get any warmer - it appears to me
that 4 degree C warming that was peak of the interglacial period before
the current one accomplished serious melting of Greenland's ice sheet. If
we burn enough fossil fuels to get atmospheric CO2 to what it was
before our fossil fuels were formed or maybe even so much as past 800 ppmv
or so (maybe needing as much as 1200 ppmv), we could achieve 7-8 degree C
warming that would melt down the ice sheets of both Greenland and
Antarctica. That would force people and businesses in currently-coastal
areas to move about 200 meters uphill, and land area above water to
decrease quite a few percent.
As for methane claptrates - I suspect we will end up minimg them for
fuel use when natural gas supply dwindles enough to spike the price up
bigtime. Sounds to me like more CO2 rather than "clathrate gun" - but
it appears to me that humans will more than avert the next ice age and end
up melting at least Greenland's ice sheet and force many millions of
people and a lot of industry to move about 7 meters uphill.
And should there be much time with Greenland being green all over
and the Arctic losing most of its year-round ice cover while Antarctica is
ice-covered, watch out for weather zones shifting a hundred or two km
northward, maybe more in "The Americas", and more-northern nations having
a lot of land too cold to farm to become greater agricultural powers. USA
will need "American Ingenuity" continuing to exist with likely
precipitation pattern shifts that will probably disfavor a lot of American
land that is "a little north of subtropical". Many Americans will also
have to cut back watering their lawns - I hope some American breeds a
strain of lawn grass that stays green when things go semi-arid.
(It appears to me that in the past several decades almost half of
Augusts in Philadelphia have almost or over half their rainfall in a
single stretch of 8 hours or less, and July and September are only a
little better than August with distribution-over-the-month of monthly
rainfall in/around Philadelphia. I doubt global warming would improve
this situation!)
- Don Klipstein (
[email protected])
