Conservation CD and DVD optical medias
Status
Not open for further replies.
14,311
Make a backup copy on a hard disk drive so you can burn a new disk if the original disk fails. That saved me some trouble when self-made disks began to show read errors.
Or make regular copies of the original disks to new disks.
In general store disk in a dry place at moderate temperature. Protect from sunlight.
gamer87
Mar 11, 2017
261
humidity here variates 50-67% temperature variates 30-35ºC
Martaine2005
May 12, 2015
5,317
Cryogenics might be your only answer.
This goes against everything you know. Your normal freezer wont cut it at 0.4-12c.
Get a Silica gel enhanced Neocrydium sulphaticum gel pack. Not only does the process of removing rust (oxidation) and age compensating chemicals (rejuvenation) of your 80s gear actually work, It only works with certain kinds of plastic.
dave9
Mar 5, 2017
1,191
Encase them in amber, then pile a mountain of silica gel on top, then put in an air-conditioned vault, underground. Fill in the access tunnel with soil and plant a tree over that. Build a tree house in the tree in a few decades. Put a machine gun turret in the tree house. Get the property declared a historical landmark. Remember, it's not only nature that is the enemy of your data.
Above all else, never let sun or light or air or humans (animals have no interest in DVDs, except monkeys, keep monkeys away) get to them. Never check on them, never access them. Do not use a GPS locator emanating a beacon. Do not lead anyone to your stash. They must stay there forever. o_O
If I didn't already have some context behind your several related posts, I would have just told you to rip the ISO images to a flash drive, then once every decade or two, copy that to a new flash drive. Flash memory is non-volatile but will lose data after a few years, or even less if it is nearer its write cycle limit which it won't be if it is a new flash drive used only once to write the data to.
THAT, you might have a legitimate reason to pack with silica gel, in an opaque waterproof container and store in a temperature controlled room, if everything around you is corroding, while most people could just keep one copy in a drawer and another in a safety deposit box at the bank.
If you want to spend more money for the more time tested strategy, rip the ISOs to magnetic tape then store as above in a vault, humidity and temperature and light controlled. The tape drive interface and driver/host-OS compatibility should be considered, to have a host capable of reading it decades from now, at which point you may find your tape drive has rotten rollers, gummed up grease, and won't work unless maintained over time. IMO, USB flash drives are more likely to be supported without that hassle.
Status
