Constant Voltage Transformer Question
David Lesher
At work I've found this happens with three phase, and I've seen the
neutral wire carrying substantial current, especially when I measure the
current near areas where there is one or more copiers. They seem to
have a very high current draw at times, when the fuser comes on.
When HP-35's and such were first appearing; I read a story about a
building where HVAC motors, fluorescent lamps, elevators, and you
name it all failed regularly. Only clue was TI calculators would
regularly crash if plugged in.
After a large effort; turns out the Mini-sized (as in British car)
copier machine was putting nasty spikes on the line/neutral, nasty
enough to degrade motor insulation and other windings. They fitted
it with (!) lightning protection (Poly-phaser or such) and that
solved the issue. One wonders how ?Xerox? got UL approval....
John Woodgate
I read in sci.electronics.design that David Lesher <[email protected]>
enough to degrade motor insulation and other windings. They fitted it
with (!) lightning protection (Poly-phaser or such) and that solved the
UL approval for what? There is no product safety issue. There IS an EMC
issue, but the US has not adopted IEC/EN 61000-3-3, which would probably
have caught the problem.
Rich Grise
And inside the microwave is a ferroresonant xfmr.....
It turns out, at least in the last one I took apart, it _looks_ like a
ferro, but that oil-filled cap is merely the filter cap in a half-wave
doubler. The tranny looks like a ferro, because the primary and secondary
are separate windings, with a space between them. But there are no shunts,
and no resonant winding. )-;
It's a linear transformer, and the cap is only a HV oil-filled cap.
How mundane. ;-)
The maggie _is_, however, the other diode in the half-wave doubler. ;-)
Cheers!
Rich
Mark Zenier
There are shunts (or some sort of welding trick), so that the transformer
current limits. It's like a Neon sign transformer.
Mark Zenier [email protected] Washington State resident
Rich Grise
I tried to post this as an attachment, but my post seems to have gone
to the bit bucket. As I said in the other post, I stand corrected.
Thank you. I realized I have a uWT right here, so "I'll take a picture
to prove my point," I sez to meself.
Imagine my surprise! :)
http://www.neodruid.com/images/dscf0145.jpg
Cheers!
Rich
Similar threads
