Contact pattern shifted toward the tooth tip
Kathie
Sep 24, 2026
Hello everyone, the backlash on this worm gearbox is adjusted using eccentric sleeves located at both ends of the worm.
Recently, due to excessive backlash, I tried adjusting the eccentric sleeves. While the backlash did decrease, a red lead check revealed that the contact pattern had shifted toward the tip of the worm gear teeth; the meshing area was significantly reduced, and the operating noise increased.
I suspect that adjusting the eccentric sleeves altered the center distance between the worm and the gear, causing the meshing position to shift.
I would like to ask: what are the correct steps for adjusting backlash using eccentric sleeves? How can I ensure that both the backlash and the contact pattern meet specifications?
Thanks in advance for any help or guidance you can provide.
Alec_t
Jul 7, 2015
3,821
This site and forum are for electronics questions. You will likely get better answers from a car forum.
