Control Circuit for a ( Linear motion ) Motor
BM Engineer
Mar 12, 2017
10
I want to build a circuit that would supply a motor of the following type:
Megamat MCZ 2 Easy
This is used to move a patient chair in a linear monition up or down.
These are the technical specifications:
Please what are your suggestions Do I have to use a circuit with a power supply, or I can use battery powered circuit for this load? What parts do you recommend to use? relays are suitable ?
Alec_t
Jul 7, 2015
3,818
You might also want to add a circuit to prevent sudden reversal of the motor.
Minder
Apr 24, 2015
3,560
Forgot: on the subject of power you could just use a simple step down transformer and a bridge rectifier, the ebay type controllers usually have any capacitors built in.
This is if the chair is used in just one permanent location.
M.
Minder
Apr 24, 2015
3,560
Then a simple joystick would work, you need a reversing relay unless the J.S. has enough contacts.
M.
