audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Chester,
Welcome to our forum.
On your website I like your propclock and big sparks. Good luck with your 15KW sine-wave inverter project.
This 30V/5A lab power supply:
If your custom-wound transformer produces 28VAC with a light load, then 44V-rated opamps are almost at their limit. Just hope that your mains voltage doesn't increase 5% like mine does at times. The calculations are as follows:
1) The peak voltage of 28VAC is 28 X 1.414 = 39.6V.
2) The rectifier bridge has 2 diodes conducting in series with a resulting voltage drop of 1.4V, so the positive voltage is 38.2VDC.
3) Add the negative supply voltage of 5.6V and the total is 43.8VDC.
You still have a 200mV margin of safety!
The voltage will be slightly over 44V if your 5.6V zener is 5% high.
I don't think that you will get 30VDC/5A regulated though, as follows:
1) Fully loaded, the transformer's output (600VA!) will probably drop to about 27VAC RMS, but its peak voltage of 38.2V will drop further during momentary rectifier current of 25A down to about 37.2V.
So the transformer's output sine-wave will have flattened peaks.
2) The rectifier bridge will probably have a voltage drop of 2.2V when conducting momentary current of 25A, and the voltage is now 35.0V.
3) A 10,000uF capacitor will probably have about 1Vp-p of ripple when fed with full-wave rectification and having a 5A load, so now the voltage is down to about 34.0VDC.
4) The three 2n3055 transistors may have a b-e voltage of 1.2+V with a collector current of 1.67A each, plus the voltage drop across the 0.1 ohm emitter resistors of 0.17V drops the output voltage to 32.6V.
5) The TIP31A for Q2 could have a b-e drop of 0.8V with a collector current of 125mA, dropping the output voltage to 31.8V.
6) If it is only 100 ohms, R15 will further drop the voltage 0.2V down to 31.6V.
7) The saturation voltage of U2 could be as high as 1.6V, dropping the output voltage down to exactly 30.0V. Just makes it? Nope, I'm not finished yet.
8) 5A through R7 (0.27 ohms) will drop the output voltage down to 28.65V. Not enough.
You might get lucky and have a lower voltage drop on your transformer and transistors, but then the maximum voltage output will probably have lots of ripple each time your 'fridge or AC turns on.
Caution! Do not use the negative offset adjustment as shown for U2 on our schematics, with your OP177 opamps. Their offset voltage control must connect to the positive supply, instead of the negative supply like most other opamps.
They have a fantastically low offset voltage anyway, so you don't need to adjust it.
The OP177 has a voltage gain that is 10 or more times less than most other opamps, so your project's regulation and ripple will suffer.
If you want 30VDC/5A that is well-regulated and has low ripple, then maybe you should re-consider using a 30VAC transformer and OPA445AP high-voltage and high-gain opamps.
