Xenobius,
So you want me to custom-modify this project for your custom-made transformer?
OK, here goes:
1) The 30VAC, 5A winding is rated for 150VA. Therefore the maximum continuous DC output current is only 3.5A. Fully loaded, the peak of the 30V sine-wave is 42.4V, but could be only 40.4V due to high momentary rectifier current. Your 6A rectifiers could have a voltage drop of 1.25V each, for a total rectifier loss of 2.5V, which results in only 37.9V being fed to the filter capacitor, C1.
Use a 10,000uF/50V capacitor for C1, in order to keep its ripple voltage down.
2) If your project's output is shorted and is set for 3.5A, then Q4 must dissipate 133W. This is far too high for a single 2N3055 transistor.
Use two paralleled 2N3055 transistors for Q4, and include 0.1 ohm emitter resistors with each, as shown above.
Use a huge heatsink or fan cooling.
3) The current gain of each 2N3055 at 1.75A could be as low as 40. Therefore their total base current is 88mA maximum. With your project's output shorted at 3.5A, Q2 must dissipate 3.2W. This is far too high for a 2N2219 transistor.
Use a TIP31A transistor for Q2, bolted to a medium heatsink. Note that it has a different pin-out and will need support.
4) The current gain of a TIP31A at 88mA could be as low as 45. Therefore its base current is 2mA. Therefore 2V is wasted across R15.
Use 100 ohms for R15.
5) R7 was originally designed for 3A.
Use 0.39 ohms, 10W for R7.
This modified power supply will easily give at least 32VDC well-regulated voltage at 3.5A.
6) Your 30VAC transformer winding could deliver 32VAC unloaded. Therefore its peak is 45.3V and the rectifiers will drop it to 44.1V. The ICs will have this 44.1V as a positive supply in addition to their negative supply of 5.6V from D7, for a total of 49.7V. This is far too high for regular opamps.
Use OPA445AP opamps for U1, U2 and U3.
