Hello everyone
Im in the process of building this PS.. Using the updated SMARTER kit schematic posted in this thread... I know there has been tons of talk about using higher voltage OP amps and issues with under rated transformers.. Ive read both threads about 1.5 times... - alot of info to digest
Im building this with parts on hand.. which happen to be very close to those specified in the schematic. My OPamps are 44v OP177 types...
now believe me I know they should be rated for more, but im stubborn and want to try with these for now.. if they start smoking ill try something else
Now because im trying to get about 5A... basically the most I can (the actual output will be measured later). I know this entitles using a higher voltage rated transformer, because of all the drops incurred along the way.. I also know that lower VA transformers have bad voltage regulation.. and would float at a much higher voltage when not loaded.
So Im rewinding a microwave oven transformer.. Rated at about 600 - 800 W im guessing (still have to get out the scale to weigh all that iron). Ive removed the secondary and the primary looks real nice. Im going to determine the V/T ratio tomorrow with the original primary.
My first question is:
What do you think a good unloaded secondary voltage would be?
I think 26V AC is the max I can go and stilll keep below the 44v DC OP amp limit, because 26v * 1.5(because of AC RMS to near peak conversion)= 39v +5v(for - supply) = 44v ( ignore the extra .6v or else its over= I like to live dangerously ; )
Will 26v AC unloaded be enough to deliver 30v DC loaded on the output? Keep in mind the transformer core is rated for about 600W
I will be able to change the secondary turns/voltage without too much trouble later on... I just want a good starting point.
Thanks, Chester Lowrey
http://www.hot-streamer.com/hilo90mhz/
