Convert Leds to 7 Segment Display
-=Almazick=-
I would like to convert 6 leds to 7 segment display. What is the best way to
do it? The way it works right now that LED's lit up in a continuous style
(for example: 1st will light up the 1st LED, 2nd will light up the 1st and
2nd LED, 3rd will light up the 1st 2nd and 3rd LED's, etc. etc) I got 7
negative inputs and 1 positive signal as you can see from the picture that
every led get grounded to lit up.
http://www.electro-tech-online.com/viewtopic.php?t=2786&start=0&postdays=0&p
ostorder=asc&highlight=
K
Ken Taylor
What is it you are trying to achieve? Do you want to have the 7-segment
display indicate the numbers 1,2,3, etc or just light up the segments in
order? If you want to indicate the numbers, you need a decimal-to-seven
segment priority encoder.
On the assumption that you may be doing this for a car battery indicator,
look at:
http://www.electronic-circuits-diagrams.com/carsimages/carsckt1.shtml
It'll give you ideas anyway if this isn't exactly the application.
Ken
