Mysteryname
- Sep 6, 2010
- 11
- Joined
- Sep 6, 2010
- Messages
- 11
With a load the voltage didn't go over 10VDC. but If I ride down hill I will expect the voltage to become much higher than that. Because I am spinning the wheel by hand.
I have compiled a list and a order form.
LM2575's are only ever sold in bulk, So I found LM2595-5 (fixed at 5 volts) I read the datasheet cover to cover and I made a selection of all my components from the recommended list. Based on the variables of the circuit.
I was lucky to come across another built switch mode regulator very similar to one the I'm building. That helped identify the components that I'll be using.
I'll be ordering the parts very soon then building a prototype on the bread board.
then simulating all the variables that I can before soldering the circuit together.
This is the component list. All the extra caps will not be used.. I just cant order any less of them.
But this has come a long way with amazing help from you guys. Thanks so much for helping me this much.
