current division in circuit
duke37
Jan 9, 2011
5,364
Try using ohms law.
With ideal components, in the first circuit, you have a 1V source and a zero ohm short. What is the current?
Is this possible?
scientifico
Mar 13, 2012
62
There is 1/0 that isn't possible, does that mean that with real components nearly all the current would pass in the wire and nothing in the 2 resistances?
duke37
Jan 9, 2011
5,364
In a practical circuit, there will be resistance in the voltage supply and resistance in the wire. The voltage across the resistors will depend on the values of these.
scientifico
Mar 13, 2012
62
if the wire resistance were 2 ohms and the voltage supply 1 ohm will the current be:
1/((1/100)+(1/100)+(1/2)+(1/1)) = 0.66 ?
duke37
Jan 9, 2011
5,364
Its not what I get. The three resistors in parallel have a resistance of 1.92R.
Add 1R for the source gives total resistance 2.92R.
Current =1/2.92
scientifico
Mar 13, 2012
62
Yes it's just because i putted the battery internal resistance as it was a fourth resistor in parallel with the other three... for example if a connect 2 same batteries in parallel both with an internal resistance of 1 ohm, will the total resistance be 2 ohm?
Battery internal resistance is modelled as a resistance in series with a voltage source, not one in parallel with it. You can't have other resistances directly in parallel with it.
