DC-DC Buck Converter
stewart
Mar 18, 2016
6
Hi
I am doing a project that needs to step voltage from a 36 V battery to 5 V to 3 loads.
if each load needs 5 V and roughly the same amount of current of 2 A.
then can I buy a buck converter that out puts 5V 2A to supply 3 loads in parallel each needing 2 A or will i burn my buck converter?
plz plz plz help
Gryd3
Jun 25, 2014
4,098
Hi
plz plz plz help
Where in the world did you find a 36V battery?
Simply find a 5V Buck Converter rated for 6A at the bare minimum.
What are the loads? If it's a heavy inductive load, then you could fry if you don't have proper protection on the motors.
stewart
Mar 18, 2016
6
the battery i am tapping into is that one that came with my electric ATV, thought would be a good idea not to get an external battery.
loads are raspberry pi or arduino still didnt decide, ultrasonic sensor and a servo motor
Gryd3
Jun 25, 2014
4,098
the battery iam taping into is that one that came with my electric ATV, thought would be a good idea not to get an external battery.
loads are raspberry pi or arduino still didnt deside, ultrasonic sensor and a servo motor
Arduino takes 2A ?!
You'll be fine. If you will be connecting it to a large motor for example, or large servo, make sure you use a diode to prevent the motor from feeding back into the circuit.
14,471
btw if max current is 12 A, does that mean under normal operation output will be only the amount my loads need, or do i need to put resistors to ensure 6 A output?
it will supply the current required by the load
AnalogKid
Jun 10, 2015
3,046
Don't know about burning up, but it might shut down due to an overcurrent.
To answer your question, when multiple loads are connected in parallel their load currents sum, or add up. So three 2-amp loads need a 6-amp source. Depending on the nature of the loads, they might draw 2 A continuously but draw more (or much more) at startup. Your DC/DC converter needs to be able to handle the transient startup current, not just the running current.
ak
