DC Motor drive
colum
Jul 25, 2013
180
Im new at this so I hope I don't make the attachments too large or small. I built this circuit and it seems to work for a small DC motor but I need to drive a motor that takes 1 to 6 amps at 27v DC
problems--DC volts shoots up to 40v from27v when Mtr turned on
Pontentiometer---Overheats and smokes
3055 did not get hot but died, 3ohms at all terminals
I probably need a blocking diode somewhere to prevent spikes or feedback
I would like to know how to upgrade circuit to one able to handle a heavier load
I appreciate you reading this ...Thanks....colum
Fish4Fun
So long, and Thanks for all the Fish!
Aug 27, 2013
481
colum,
You should look into PWM and h-bridges, but even then 6A @ 27V is fairly hefty (162W), this is an awful lot for a first go at a power circuit!
You might notice the schematic has the output limited by a 1A fuse. That is a clue.
Using a transistor as a current limit in linear mode has serious heat/efficiency issues. That said, designing a switch mode power supply capable of 6A into an inductive load also has issues, especially if it is unfamiliar ground. I would suggest you find an existing PWM DC speed controller. I have not priced any in quite some time, but I would expect you should be able to find something that will work under $200, perhaps way under if there are any in the RC model hobby or some other mass-market usage.
Fish
colum
Jul 25, 2013
180
Thanks for your advice Fish. I had forgotten about PWM drives and I can use 411 type transistors which I have used in PWM drives before but for much smaller mtrs anyway its a hobby and I have parts to burn up...Thanks...colum
