Define a Function - brutishly
chopnhack
Apr 28, 2014
1,576
LOL - My homework was completed, however, I think it was by force rather than skill:
L4 Problem 10
(5/5 points)
Define a function isVowel(char) that returns True if char is a vowel ('a', 'e', 'i', 'o', or 'u'), and False otherwise. You can assume that char is a single letter of any case (ie, 'A' and 'a' are both valid).
Do not use the keyword in. Your function should take in a single string and return a boolean.
Code:
def isVowel(char):
  char: a single letter of any case
  returns: True if char is a vowel and False otherwise.
  if char == 'a' or char == 'e' or char == 'i' or char == 'o' or char == 'u' \
            or char == 'A' or char == 'E' or char == 'I' or char == 'O'\
            or char == 'U':
       isVowel = True
  else:
       isVowel = False
  return isVowel
Is there a cleaner way of doing this?
Supercap2F
Mar 22, 2014
550
How about converting the letter to upper case (I assume that there's a way of doing that in python?) and then you only have to test for the upper case vowels.
Dan
chopnhack
Apr 28, 2014
1,576
Dan
Thanks Dan, LOL - the very same idea was presented in the next lesson! :p:D
# string.upper()
If I created a string to use for comparison, I could have then simply converted the case and retested. I am not sure if the test would be for each element in the string though as I had in the above code. I needed to capture each occurrence of the vowel, regardless of case.
Gryd3
Jun 25, 2014
4,098
Code:
def isVowel(char):
  isVowel = False
  for letter in "aeiou"
    if string.lower(char) == letter
      isVowel = True
  return isVowel
Does this work?
chopnhack
Apr 28, 2014
1,576
Code:
def isVowel(char):
  isVowel = False
      isVowel = True
  return isVowel
Does this work?
It did not, but the automatic grader works off the principal that it will supply the input for (char). I am not sure what the error was exactly, but it pointed to the "aeiou" - does that line need a : at the end?
I guess then you could convert the contents of variable letter to upper case and test again.
Gryd3
Jun 25, 2014
4,098
Code:
def isVowel(char):
  isVowel = False
  for letter in "aeiou":
    if string.lower(char) == letter:
      isVowel = True
  return isVowel
Does this work?
I missed the ':' on the For loop, and IF statement... I'm not used to those things...
(Fixed)
