Difference b/w Electrate and Condensor mikes
Muhammad Abu Bakar
May 6, 2005
145
Hello Dear All!
I want to know diff b/w an electrate & cond mike. As I replaced elctrate mike in an FM Transmitter Kit with cond, it didn't work. Electrate mike was fulfilling the job successfully earlier.
Also which one is more sensetive (If they are diff things)?
audioguru2
Apr 6, 2004
12,026
If you spelled "electret" correctly then you could have looked at its operation in Google.
The electret material holds a high voltage charge which allows the mic to work.
A condenser mic doesn't have the charge so needs an external high voltage power supply (48V) to work.
Many people wrongly call an electret mic a condenser mic.
An electret mic must be connected with the correct polarity.
They have about the same low sensitivity.
Muhammad Abu Bakar
May 6, 2005
145
The thing I am considering cond. mike, I think, also has polarity. red & black wires soldered.
Which kind of mik bears highest sensitivity?
Thanks for Ans!
audioguru2
Apr 6, 2004
12,026
Some electret mics are 2-wire and some are 3-wire. They connect to the circuit completely differently.
Your replacement mic isn't an electret type, doesn't work or isn't wired correctly to the circuit. The problem isn't a different sensitivity.
Muhammad Abu Bakar
May 6, 2005
145
Hello AU!
Yes, the replacement isn't electret one. But I wanted to experiment for better sensetivity.
Then I want to build this amplifier. Can't ther be some compromise on the voltage requiered? Any suggestions, please!
audioguru2
Apr 6, 2004
12,026
What amplifier?
Your condensor mic will have about the same sensitivity as an electret mic if you bias it with 48V and have its proper load resistance.
Look at the datasheet for the mic.
