DIGITAL COMMUNICATION
prateeksikka
Jun 19, 2004
736
hi all!
we generally talk about bits per second in digital transmission specially computer terminology.
does bandwidth have no meaning here?
shannons relation relates bandwidth to bit rate how does the relation comes?
;D
ECET0purdue
Jan 29, 2005
314
iam not 100% sure but i know they both use the same equation. And if i rember they are usually the same value. i belive they are different in the way they are used.....like i said i belive this is right but it has been awhile sence i have used it..
cheers,
glen
prateeksikka
Jun 19, 2004
736
no i mean does it make sense to say that my computer has say "B" Hz of bandwidth?
Cerium
Aug 10, 2005
18
Bandwidth is generaly the total ammount of data being moved where as you are talking about the speed. Bandwidth is measured in bps, kbps, mbps, gbps... They are both obveously related.
ECET0purdue
Jan 29, 2005
314
The transmission capacity of an electronic pathway such as a  computer bus or computer channel. In a digital line, it is measured in bits per second or bytes per second. In an analog channel or in a digital channel that is wrapped in a carrier frequency, bandwidth is the difference between the highest and lowest frequencies and is measured in Hertz (kHz, MHz, GHz).
A.K.A.
bit rate is the measurement of the bandwidth.
because it measures Number of bits/time not Distance / time
prateeksikka
Jun 19, 2004
736
Shannons theorem gives the relation that means a xhannel digital with 20 Mhz bandwidth does not carry meaning
prateeksikka
Jun 19, 2004
736
Does a bandwidth of say 10 MHz mean same as 10 MBps?
Does 10 Mhz have a meaning as such
