DIGITAL GUITAR AUTO-TUNER PROJECT
John Woodgate
I read in sci.electronics.design that Jon Harris
However, if I fret some of the strings to play a different chord where,
for example, a string that was the third now becomes the fifth, it is
horribly out of tune! So while for strumming a single chord, just
intonation is great, I have to use a compromise closer to
equal-temperament if I want to actually play a song.
Well, yes, that's precisely why equal temperament was invented.
Jon Harris
Jerry Avins said:
In a way analogous to a bell's "clang tone", the harmonic structure
changes rapidly when the string is first plucked. Don't measure the
first part of the note, and don't try for such a long measurement that
the note fades away.
My needle-based digital tuner reacts quite quickly. I can see the note appear
sharp as it is first plucked, then watch it settle in to a fairly constant
reading for several seconds until it fades away. In this case, it is up to me
as the user to ignore that initial transient reading and wait for the steady
state. Doing so is quite natural.
Rich Grise
Cue for Rich to quote the 'Old Lady of Bean'?
Sorry, but I can't find any references to an "Old Lady of Bean". )-;
Rich
Bob Monsen
dhaevhid said:
this is the exact reason why im still "hunting" the elusive precise
algorithm on how to do this project the correct way. almost every
project done( atleast those i see on the web) do not consider the
harmonics that would surely cause trouble... i saw some samples though
that used an FFT, IIR and all those stuff but i am yet to learn how to
do all of those in assembly language. i did a project using those
functions in matlab but its an included function in the library. so
its quite a degree more difficult this time to do all the FFT, FIR,
and IIR "hand written" on assembly.
A digital filter is quite simple. It is just a bunch of multiplies and
divides on each sample. However if you have to do the multiply in
software, you'll never make it fast enough, at least with the tiny
microcontrollers that are out there. A PIC 16 series requires between
500 and 700 instructions for a multiply. Using a Zilog Z8 Encore, or a
PIC 18 clocked at 20MHz, you could probably do 6 simultaneous IIR
filters using the same A/D channel (there are web pages that will write
the 'C' code for you, given the frequencies and passband width.
Translating that into asm is trivial.)
By filtering a 10Hz passband for each string, it's possible you will be
able to do the zero crossing thing, and then both select the string, and
give guidance on which way to tune as relative error. However, that is a
guess, since I haven't tried it.
John Woodgate
I read in sci.electronics.design that Rich Grise <[email protected]>
There was an old lady of Bean
Whose musical ear was not keen.
She said, 'It is odd,
But I cannot tell 'God
save the weasel' from 'Pop goes the Queen'.
Bean is a village in Kent, which used to be a quiet backwater. Now it
has a motorway for bedfellow and a huge retail complex (Bluewater:
http://www.bluewater.co.uk/) for near neighbour. Soon it will have
another complex nearby.
John Woodgate
I read in sci.electronics.design that Guillaume <"grsNOSPAM at
NOTTHATmail dot com"@?.?.invalid> wrote (in
As to how the above input stage, based on a filter and a saturation
stage, translates in the frequency domain (in other words, how
the spectrum of the original signal is transformed), I'll let you
think about it.
Thanks for the explanation. It gels with my thinking on the subject.
It resembles, but is not quite like simply looking
at zero-crossings - because the saturation on the signal actually
tends to "ignore" the harmonics, whereas simple zero-crossing
analysis has to deal with them.
Indeed: a very cogent point.
All in all, this is a working approach and it's much simpler than any
sophisticated DSP analysis you might try.
You said it! Digits are NOT always the answer. Particularly FFT.
Bob Monsen
Jerry said:
Ville Voipio wrote:
Ah, come now! Even in the best of guitars, the frets are located by "the
rule of nineteen". Pianos and fretted instruments have tuning
similarities (although you can't "bend" a piano).
Apparently, the very high and very low notes on pianos are tuned with a
larger than 2:1 octave. The ratio can be up to 2.025:1. The claim(1) is
that that this is caused by beat matching, trying to match the
fundamental to the 2nd harmonic, which is slightly off due to the
stiffness of the strings.
Thus, it may not make sense to do precise electronic tuning on stringed
instruments. I always find that my guitar sounds better when I match the
harmonic on the 5th fret of the bottom string to the top string, and
then interpolate. That makes the high E somewhat sharp (but not nearly
as sharp as a piano, due to the lower string tension.)
(1) Musical Acoustics, Donald Hall, pg 188.
Paul Keinanen
In
sci.electronics.design,sci.electronics.misc,comp.dsp,comp.arch.embedded,
This is where multiple methods come in handy. A low-pass filter and
zero-cross detection gets you in the ballpark, then your method (looks
like a PLL using a phase-accummulator DCO) gets good accuracy.
Yes indeed.
Use a 32 or 64 point FFT (with about 10 Hz bins) to detect the lowest
frequency. This can be done in a few hundred milliseconds.
After this decision, you are within about 10 Hz of the actual
frequency. If you have enough memory, buffer the first tap on the
string and rescan the samples to determine the frequency error.
If no data memory is available, analyze the next tap on the string to
Paul
Paul Keinanen
Not sure what you mean here. You do need to make sure your FFT output
looks like it might represent a musical note of interest, and not just
background noise between notes.
The Fourier analysis assumes that you have a constant amplitude
_repeatable_ waveform, unfortunately a string instrument does not
generate such signals, so you have to analyze some part after the
initial transient.
Paul
Jon Harris
I know. I was just giving an example that was guitar-specific in response to a
point that someone else made that equal temperament was bad.
Jerry Avins
John said:
Can this feature be retrofitted to s.e.d contributors?
Even though I have no idea what s.e.d. stands for, I doubt you can
implement selectable intonation without getting into the firmware. In a
YDP-233, one can chose among equal temperament (the default), or pure
major, pure minor, Pythagorean, mean tone, Werkmeister, and Kirnberger,
all with any base note. You can also transpose any number of half tones
and pull the pitch of A440 in about .2 Hz increments from 427 to 453. It
doesn't sound like the Steinway it replaced (my daughter has that now),
but it's fun to play with as well as on. It will record two tracks and
has a MIDI interface. More than I need.
Jerry
Jerry Avins
A piano's "stretch" over its 7.5 octaves is the better part of a
semitone. By attaching discrete weights to the strings, most of the
inharmonicity can be removed. (The windings on the low strings end well
short of the bridges, reducing inharmonicity of the second partial.) A
piano so doctored is tuned without stretch. It sounds awful!
Jerry
Jerry Avins
Robert said:
Yes, there is in fact a "lock-in" phenomenon that happens through the
interaction at the bridge. But typical amounts of inharmonicity, at
least in piano strings, exceeds the lock-in range. Inharmonicity is
easily measured by precisely measuring the pitch of individual
overtones and comparing them. Another way to verify inharmonicity is
to observe the signal on a scope. If the overtones were all locked to
the fundamental, the overall shape of the signal would be constant,
just decaying in amplitude. Perhaps the individual overtones would
decay at different rates. But it would be quite clear that the
overtones are frequency locked. But that is not in fact what you will
observe. If the scope is triggered by the fundamental, then the
overtones will appear as higher-frequency components that are "riding
to the left" as compared to the fundamental.
I agree. One point of quibble: even if the overtones were frequency
locked, the wave shape would still change with time. Different overtones
have different decay rates.
Jerry
John Woodgate
It stands for a very great deal, and it's the newsgroup you are
participating in.
Jerry Avins
Al said:
[email protected] (Robert Scott) wrote in
I observed this many years ago using an FFT analyzer. As I recall (25
years ago),I also noticed that the G string on my guitar was actually
vibrating at two different frequencies that straddled the desired center.
I think this is why I never think that a B created at the 4th fret of the
G string ever sounds perfectly in tune with the B string. I attributed
this to the fact that the G is a wirewound string and therefore has
significant thickness.
Winding adds far more mass than stiffness, making the string more
harmonic. Some materials are better than others. Fine silver is used for
violins and cellos. Gold is be better. :)
As was mentioned earlier, the choice of temperment is always a
compromise. The frets contribute to temperment as well, I wonder what the
best compromise tuning is for a guitar given all the various parameters.
You might start with the fact that a guitar is usually tuned E A D G B E.
I suppose a smart tuner could have open tuning capabity as well. Open
tunings might be easier to consider if you want fifths and thirds etc to
be perfect (1.5 vs 1.4983 & 1.25 vs 1.25992)
Piano tuners fight the temperment issue all the time. If I have a piano
tuner come out and tune my piano to even temperment (unfortunately, the
typical situation), I hate the sound. I used to have a guy who tuned most
of the pianos for the recording studios in my area tune my piano. When he
did the tuning, my piano sung!
There was a guy around Princeton who tuned pianos for concertos and
quintets that almost changed the character of the music. It would soar.
I can't remember more, and the one guy I could have asked is no longer
around.
Too bad I can't actually play very well.....
Yeh. :-(
Unfortunately (fortunuately) I have a pretty good sense of pitch.
Mine comes and goes.
Jerry
V
Ville Voipio
By comparing the frequency with a few preset ranges, the tuner can
even guess what the string it is you're trying to tune, and
automatically give you how far away you are from the nominal
frequency for this string.
Thank you for the thorough explanation!
The tuners I've been using seem to be able to guess the tone within
one half, i.e. 5.9% in frequency. This seems to work pretty well,
even though the detection is sometimes inconviniently slo.
However, I've always suspected the tuner measures the frequency
directly and after that finds the nearest note from a LUT and
then calculates the remainder. There is a LED bar display
to show which note (A, A#, B, C, ...) is playing and then an
analog meter to show the deviation from the even temperament
(+-50 cents).
The tuner is quite fine with violins, flutes, and even piccolo flutes,
but not very good with cellos, double basses, bass viols or other
low instruments. It does find the correct note, but the detection
is then very sensitive to higher-frequency noise.
think about it. It resembles, but is not quite like simply looking
But wouldn't a combination of an AGC and a hysteretic comparator
be still better? The saturating stage does give some false
zero crossings even though it filters out a lot. But shouldn't
hysteresis filter all false crossings out, if the sum of
amplitudes of harmonics is smaller than the hysteresis?
Jerry Avins
Guillaume said:
Most of them use a simple design. You can find one on CircuitCellar,
and that's pretty much how this is done in commercial products.
It consists of an input stage, which is basically a good low-pass filter
filtering everything above the maximum fundamental frequency it's
supposed to deal with (probably something like 1000 or 1500 Hz), usually
a 2nd order active filter. Then it's followed by a comparator set with
some hysteresis, which can also be an amplifier based on some AOP with
a lot of gain - so that the AOP clips the signal, which is easily
transformed into a digital signal with a schmitt trigger, for instance.
This circuit basically extracts the fundamental frequency of the input
signal with a reasonable usability.
Then the comparator's output can be dealt with in various ways.
Some can be rather crude (just measuring the frequency of the resulting
digital signal), some are more clever, and I like the one that's used
in the CircuitCellar project. The comparator's output goes to a digital
I/O pin of a microcontroller, of course set as an input. The algorithm
used consists of measuring the delay between two consecutive raising
edges - but this is not all. To make sure the measure is meaningful,
several consecutive measures are compared, and only if we get a few
(like 10, for instance) consecutive measures that are close enough
to one another, do we consider this is the fundamental frequency.
The latter is computed from the period, using for instance an average of
the 10 given "meaningful" past measures.
I've agreed so far, but not here. The zero crossings of the comparator's
input and output had better coincide in time (with offset allowed for
hysteresis). Those squiggles away from the crossings will be suppressed,
but they don't matter anyway.
Some wouldn't even call it DSP, but I processed many signals that way
for many years.
Jerry
Jon Harris
s.e.d. = sci.electronics.design. I think this was a joke, playing off the word
"temperament". Get it?
V
Ville Voipio
Depends on the fretted instrument. The idea of fixed frets is
a new one, older instruments tend to have movable frets.
My viol (viola da gamba) has tied frets, and I really have
to move them depending on the temperament. Actually, the
deviation from even temperament is very visible (some
frets are closer to each other than others). And talking about
bending... some of the frets are actually non-horizontal
to give better temperament.
Pianos are sometimes tuned in even temperament. Sometimes not,
many tuners like to make them slightly tempered some way or
another. It is a common misconception that the even temperament
was invented by J.S.Bach (Wohl-temperierte Klavier). The even
temperament was well known in the baroque era -- well known to be
a bad compromise. What Bach discovered was yet another temperament
system which allowed him to play in all keys. The keys sound
fine but different.
I want to make it clear that I don't have any golden ears,
which would be able to detect the frequency down to microhertz.
But the fact is that I have to tune my frets to suit the
needs and temperament of the rest of the band. In that task
a tuner makes life much easier (without the golden ears I
can only say something is wrong :)
I know it sounds a bit odd, but early music (especially baroque)
players use auto-tuners a lot. For example, tuning a harpsichord
without a tuner takes much longer. It is still possible with some
experience on listening to the weak harmonic beats, but slower.
Or, keeping a viol consort in tune during a longer concert is
much easier with some fixed frequncy reference.
<aside> Do you know Roland Hutchinson? (He was quite taken with the
selectable temperaments on my recently acquired Yamaha "piano".)
Yes, I know him (not personally, though). No, I am nowhere near
that level.
(I just wonder if there was anything not off-topic in this posting?)
- Ville
