Diode 1N2007
pop-pop
Jan 1, 2022
6
Is this diode still current and/or is a substitute available. Cannot locate spec sheet for 1N2007
pop-pop
Jan 1, 2022
6
I found that data sheet also, but not enough specs are given. I have a feeling it is obsolete and has a substitute of some sort;. cannot find a dealer who carries this diode.
bertus
3,882
An 1N5280B seems to be a replacement:
Added remark line at picture
Bertus
pop-pop
Jan 1, 2022
6
WOW! Thank you for the data. I thought it may have been a zener, but not positive. I weill research for a dealer.
You must have a pretty good source for diodes.
Thanx again.
14,317
there are other 190 Volts zeners available:
The 1N2007 is a 560 V zener...
I wonder why the 1N5280B (190 V) is given as a replacement for the 1N2007 (560 V). I can't find a 560 V zener. You'll probably have to gobble one up by adding multiple lower voltage zener diodes in series.
bertus
3,882
@Harald Kapp , You are right, I have added the remark line at the picture: Use a matched set to achieve voltage rating.
It looks like that 4 times 1N5280 in series are needed.
Bertus
14,487
The 2N2007 is a 560 V zener...
I wonder why the 1N5280B (190 V) is given as a replacement for the 2N2007 (560 V). I can't find a 560 V zener. You'll probably have to gobble one up by adding multiple lower voltage zener diodes in series.
Harald ...that should be 1N2007 NOT 2N2007 (which is a MOSFET)
please edit your post :)
