Driving Peltier Device through L298N to control Temperature
sachin2611
Sep 10, 2013
9
Please verify beloved attached ruff block of schematic.
Sachin
Your PWM+ and PWM- connections are just the current direction (i.e. heat/cool)
The one you've labelled MCU pin is more likely to be the PWM.
attachment.php
This is shown without feedback, so the PWM would vary the current, but you wouldn't be able to set an exact value.
Your inductor and maximum on time (and minimum off time) have to be chosen carefully to determine the maximum current and ensure the inductor doesn't saturate.
With feedback it's easier.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
This is what I'm suggesting.
attachment.php
The main power supply generates a voltage around 30~35V at about 5A maximum. This voltage feeds into a buck converter with variable output voltage or current, which feeds through the H-bridge to the Peltier device.
Ideally the buck converter would provide a variable current, with the actual current determined by an input that would be driven either from a DAC in the MCU, or from a PWM output from the MCU that was then smoothed with one or more stages of R-C filtering.
An alternative would be a voltage-regulating buck converter and a current monitor. The MCU would then control the converter's output voltage to achieve the desired current. I've shown the current monitor in the positive feed from the buck converter to the H-bridge but it could also be in the negative return of the H-bridge, for convenience. (A high-side current monitor is more complicated than a low-side current monitor.)
The H-bridge needs to be driven by a proper H-bridge driver IC that can generate the higher positive voltage for the top two MOSFET gates. Some of these driver chips are designed to monitor the current flow through the bottom MOSFETs to the 0V rail and they may be able to provide a convenient current feedback signal to the MCU.
When you change the polarity of the Peltier voltage by changing the control signal to the H-bridge driver, you should first ramp the buck converter voltage down to zero, or disable it completely, otherwise you may see a voltage spike from the converter during the dead time when the H-bridge switches from one state to the other. A reasonable amount of smoothing on the buck converter would probably avoid this, though.
My original suggestion was to combine the mains-powered supply with the buck converter, but you can use two separate converters if you want.
Comments Steve?
Fish4Fun
So long, and Thanks for all the Fish!
Aug 27, 2013
481
If I could make a suggestion, why wouldn't you just use a relay to reverse the current? I mean I love an H-Bridge as much as the next guy, but a relay has guaranteed break before make with built-in dead time between. I just cannot imagine why you would need an H-Bridge here. Maybe I am missing something?
Fish
KrisBlueNZ
Nov 28, 2011
8,393
Good idea Fish! A DPDT relay wired as a reversing switch would be simpler and cheaper than an H-bridge.
Fish4Fun
Aug 27, 2013
481
hehe, kinda what I was thinking ;-)
And less to go wrong :)
As mitigation, if the H-Bridge were driven from a constant current source, a mistake would probably not be catastrophic.
