Can somebody help me with a project?
For hearing impairment: I need to change a "beep" into a "vibration", and a analog meter needle into a rapidly flashing LED. This would allow my wife to enjoy the hobby of metal detecting, despite her hearing loss. I know very little about electronics, so please bear with me. Instead of a audio signal that gets higher pitched as the detector coil comes closer to a buried target, I need to build a wrist band or earlobe clamp that will vibrate when a buried target is detected. The vibration motor or device would need the ability to increase cycles or oscillations as the detector coil comes closer to a target. So ideally, the vibration would grow in intensity and decrease depending on signal strength. I would also like to convert the meter signal to a flashing LED...instead of a swinging needle. Ideally the LED would flash more rapidly as the target gets closer. A solidly lit LED would indicate dead center, or pin pointing of target. I know this is possible to do, under water detectors operate this way. But can it be done retro? and how complicated would it be. Even if this sounds like a stupid question or project, I would really appreciate any input at all. Or showing me the direction I need to take.
Thank you for your time, plumber
