Dual polarity power supply for circuits
dayanj
Sep 16, 2010
15
I am looking for a dual polarity (+/-6V) power supply for use with simple circuits.
I found these DC to DC converters which have +/- 12V outputs. Do you think I can use that +12 and -12V outputs connected to two potentiometers to regulate it to any voltage below 12?
I have attached a sketch of what I plan to do? are there any potential barriers for using it like this?
thanks
DJ
14,487
hi there DJ
a voltage divider like that would be ok for low currents any signif current and the resistors are gonna get real hot.
you would be better off using +5V and a -5V voltage regulators off each of the + and -
rails. (3 pin 7805 and 7905 Reg chips for example)
You didnt state what your power supply's current capabilities need to be ? ie. what sort of current is the load going to draw from each supply rail ?
shrtrnd
Jan 15, 2010
3,902
Yeah, a little more info about what you're going to use it for, would help.
If you need the 6VDC, you could bump up to the 7808/7908 (8Volt regulators), with a fixed resistor to drop the 8V to 6V. If you expect high currents, get the TO-3 power transistor package. And like davenn said, you gotta be aware of your current draw, for the right size dropping resistor.
A high current dc/dc converter is going to run you some cash, and the voltage regulator idea from davenn would be a lot cheaper.
dayanj
Sep 16, 2010
15
Thanks a lot for your replies!!
My applications are phase locked loop with LM 565/ NE 565 in FM demodulation mode,
and some simple op amp circuits like voltage multipliers etc.
I found that voltage regulators, which seems a good option for me to use combining with +12 and -12 outputs of DC-DC converter. Thanks a lot again!!
shrtrnd
Jan 15, 2010
3,902
Low current circuit, ....
Your circuit should be pretty simple and inexpensive.
dayanj
Sep 16, 2010
15
btw, are there any dual polarity power supplies commercially available for this purpose?
ideal one should have three outputs wit +,- and ground. and output can vary between +/- 5V to +/- 12V ?
Militoy
Aug 24, 2010
180
If you don't need more than around 100mA on each output - you could use a dual adjustable LDO linear regulator like the LT3032. They're good for +/- 1.22V up to +/- 20V or so. They're not technically a "power supply" - as you'll have to feed in unregulated DC - like from a dual-complimentary rectifier.
dayanj
Sep 16, 2010
15
Thank you! I think that is the best option for me for my range of applications!!
