In sci.physics Jeff Liebermann <
[email protected]> wrote:
As far as model airplanes go, I haven't seen many (actually none) landings
I'd call a greaser.
I see this a bit different.
In many model (toy ;-) ) airplanes you will find at least a solid
state giro.
In some model helicopters the giro is an inherent part of the design,
for example the Draganflyer, have a look here:
http://www.draganfly.com/
So, I think that when Le Chaud Lapin talks about 'the next step', he
is
not proposing to control the wires, he must be proposing to control
the auto-pilot system.
It is the task of the auto-pilot system to make sure the stress limits
of the airplane are observed.
You tell it heading, altitude, and speed (which it can override, it
will know minimum airspeed).
One step further, and imagine even if 10 % of the people who use cars
now, will start
using airplanes, then the airways will be completely full.
There will be a plane ahead of you and one behind you all the time.
You get into the plane, type destination into the computer,
The computer will get the weather between where you are and your
destination,
tell you to take a train or car if it cannot find a safe route, it
will tell you
how much [nore] fuel you need, it will run all checklists, it will not
forget flaps
(the recent crash in Spain I did read may have been caused by that),
and it will
run the takeoff program.
Then it will run the navigation program, connect with ground to make
sure
it is in the right position relative to other aircraft, and at the
destination
it will run the landing checklists and program.
It will not forget to put the gear down....
So you - [computer - autopilot] airplane.
It is the only way there can be that much traffic.
With all manual controls except the destination field to type in gone,
sure some people will complain that that is not really 'flying'.
For those the Cessna or Tiger Moth, or whatever, they can fly in
reserved areas,
like we now have race tracks for people who MUST break the speed
limit.
When something goes wrong, of course there is not much you can do, as
you cannot fly,
and even if you could there are no controls... A message will be
displayed:
'Kiss yourself goodbye', or if you are lucky : 'parachute under your
seat, jump now',
or 'any preference of farm you want to buy?'
This is not much different from a passenger jet, no parachutes
either... only
life vests, even if you fly over land....
