Electrical stove on DC?
snote
Apr 9, 2019
4
I have a power source, 4x 34V solar pannels, =136V DC!
I want to use the power to drive an electric stove.
I have a one burner stove, it needs 110V AC.
My question. Is it safe, to use it on DC? If not, what have I
to change to make it work?
Sven
Minder
Apr 24, 2015
3,561
The element itself is no problem, but there is certain to be AC related circuitry involved that may preclude it being used totally on DC.
M.
snote
Apr 9, 2019
4
Thanks for your answers!
The cables are directly connected to the heating coil. There are only 2 control bulbs implemented.
The solar panels should deliver 1000w, the stove is rated with 700w.
If a cloud would pass and the current would go down, could there anything else happen than the stove running colder?
14,317
Plus: The switches and possibly relays within the oven are designed to operate on AC, specifically with respect to their turn-off capability: When a strong current is interrupted (turned off) it tends to create an arc across the contacts. With DC, a comparatively low voltage is sufficient to sustain the arc and the contacts will burn away (you're lucky if it's only the contacts). With AC the repetitive zero crossings of voltage and current help to turn of fthe arc.
snote
Apr 9, 2019
4
Yes, I see, thanks!
I will try to connect the pure heating element through a 250VDC/720A heavy duty switch and see in practise if it makes sense to use it without termostat.
FuZZ1L0G1C
Mar 25, 2014
366
What about this? (depending on your budget of course)..
Solar panel charges lead acid battery(s).
Battery supplies power to power inverter of 110VAC with sufficient current rating (1KW or more).
