Hi Doctor Emad,
Which circuit did you constuct? (We have many, now). I don't know why it doesn't work, when it worked before but was noisy. It should work fine and with less noise with the TL072.
The "auto" stethoscope that you posted is very similar to our corrected one, but uses a 3-wire electret mic and has much more gain (and therefore more noise). Its simple "tone control" noise filter is not nearly as good as our corrected U2 precision filter.
The NE5532 has lower noise than a TL072 but still has noise. I have used both for mic preamps and they sound the same (perfect).
Since the "auto" stethoscope circuit doesn't use a power amp, it must be used with high-impedance headphones.
Now that you have constructed our corrected circuit (I hope that you built that one), don't you want to troubleshoot it? There is probably something very simple that is wrong.
If you speak into the microphone, about 20cm away, do you hear your voice clearly in your earphones? The U2 filter will reduce high frequencies but your voice should still be heard.
When you turn its volume control down, does the noise reduce to nearly nothing?
What does the noise sound like?
