Hi Del,
You are correct, TR1 in my add-on circuit is a transistor, the type depending on the load.
It would be hillarious to watch a video of an intruder who is startled by your sound effects and fake tear gas! He would jump right out of his skin.
A problem with using a 555 as a delayed activation timer is that its output is the same before being triggered as it is after the time period. It is designed to give a timed output duration beginning immediately after being triggered. I don't even think it will work with 2 cascaded 555's, with the 2nd being triggered when the 1st times-out. The 2nd would be triggered continuously prior to the 1st being triggered.
Another problem is that the trigger input signal must be released just prior to its timeout, which probably won't happen with a noisy burglar. It wouldn't be difficult to gate the trigger off during the time period.
I fixed a project here that changes the brightness of a blinking LED depending on the resistance of an object between its probes. It uses an AC signal between its probes to avoid ion migration and probe plating/unplating and has a range of a few thousand. Although originally intended to indicate the dryness of a plant's soil, another chemist used it to indicate salts concentration in a solution. Maybe you can use it like that or to indicate that a chemical reaction has finally occurred. The project is here:
http://www.electronics-lab.com/projects/science/018/index.html
I will try your recommended "silver solder" and get the lead out.
