audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Aaron,
It is great to hear that you got it working. ;D ;D
But it is too bad that it passes friction noises.
In my test setup, I used a soft, thick rubber grommet around my electret microphone to isolate it from friction and handling noise conducted from the stethoscope head. I used a very flexible shielded cable to stop noise from being conducted down the cable.
I didn't use a proper head, instead I used a plastic jar lid that made many noises because it wasn't heavy. With a solid heavy head that is used with some lube, you shouldn't hear many friction noises.
The circuit's lowpass filter passes 25Hz to 30Hz heartbeat sounds and their lower harmonics up to 103Hz, and reduces the level of higher frequencies caused by noises. The circuit's cuoff frequency is 103Hz if C3 and C4 are 47nF. If you use 3.3uF then the circuit will have a cutoff frequency of only 1.5Hz and the important heartbeat sounds would barely be heard and lower harmonics would not be heard at all.
Be certain that your headphones can reproduce the very low frequency of heartbeat sounds. Some headphones have a boost at 100Hz to give a false effect of bass, but cutoff lower frequencies.
