Electrotechnique homework
rtkozngm
May 30, 2023
7
Hello everyone. I'm an university undergrad. 1st year doing electrotechnique. That's the name of the class I need help with. It is similar to electronics, but it is mostly focused on analyzing current and voltages in schematics. I would appreciate any help you can give me and point out what am I doing wrong.
I have made my own work, but it is likely it's wrong.
  • electro.zip
Think you may need to place your problems here, not zipped up, could be suspicious files enclosed.
kellys_eye
Jun 25, 2010
6,512
I'm not about to open a 'strange' zip file. Post the actual files (pdf, image, whatever) and we'll take it from there.
Delta Prime
Jul 29, 2020
2,996
Kind of like comparing Granny Smith apples and Golden Delicious apples totally different. ;)
rtkozngm
May 30, 2023
7
Okay, sorry, I saw some other thread where ppl posted zipped files, so I did the same. Here is the 1st problem and my solution. I think I have gotten this one correct.
rtkozngm
May 30, 2023
7
The second problem:
rtkozngm
May 30, 2023
7
Third problem.(1st in order tbh). I am least confident in the last two posted exercises.
Delta Prime
Jul 29, 2020
2,996
So far good! Lunch is over got to get back to work. Will continue tonight!
rtkozngm
May 30, 2023
7
Thank you, but I'm not sure if the result of the ic(t) is correct. I asked a few of my friends and they had gotten something different at the end. I'm attaching their solution to the problem. Everything is about the same until they solve for Vc. From then on, there are a few non-equal findings.
rtkozngm
May 30, 2023
7
Found the problem. I have mistaken the x value for the y value in the Vc variable. And I have approximated too much when finding the amplitude for Ic(t). Got the 1st exercise finished at least.
Delta Prime
Jul 29, 2020
2,996
Standby
Delta Prime
Jul 29, 2020
2,996
Anything else you would like to add after the fact.
You have the proper steps
I'll see you a bit later I'll take my time.
Delta Prime
Jul 29, 2020
2,996
Apologies you are correct. I'd be happy to look at it. See you soon
