Emitter design for negative ion generators...
K
KILOWATT
Hi thanks to read. I wish to design a negative ion generator.
Two questions remains yet:
1-Whats the best emitter design for those? Simply a sharp needle is enough
or does a good design asks for many needles to have a better output?
If you check this link, they seem to have a very good emitter design.
http://www.negativeiongenerators.com/images/CFEmittercloseup.jpg
They claim the following:
"The long-life CFE ion emitter used in this model is made from a high-tech,
space-age material that is virtually maintenance-free. The CFE emitter
requires no trimming, since the diameter of the fibers is almost
microscopically small (only 0.8 microns). The CFE simply plugs into the
ionizer as shown."
Any thoughts about that?
2- What's the best voltage? Do i simply use the highest possible voltage
that will not produce a significant amount of ozone?
TIA
Alain(alias:Kilowatt)
Montréal Québec
PS: 1000 excuses for errors or omissions,
i'm a "pure" french canadian! :)
Come to visit me at: http://kilowatt.camarades.com
(If replying also by e-mail, remove
"no spam" from the adress.)
Jacobe Hazzard
generator.
needle is enough or does a good design asks for many
needles to have a better output? If you check this
from a high-tech, space-age material that is virtually
maintenance-free. The CFE emitter requires no trimming,
plugs into the ionizer as shown."
possible voltage that will not produce a significant
amount of ozone?
TIA
I have a commercial bionair HEPA filter with an ionizer that uses a single
needle.
I think if you need a special electrode like the one in the link, you are
probably producing too many ions for regular use in an occupied room. I'm
not a big believer in the benefits of negative ions, and I'm sure it's
possible to do harm with too high a concentration.
I would think that around 4-5kV on a single stainless steel needle would be
fine. If you can hear it hissing in a quiet room it's working, and if you
can smell it, it's producing ozone.
N
N. Thornton
ionizer as shown."
Use some spikes and ignore the bullshit. Just remember what youre trying to achieve.
Emitters dont need trimming btw.
Regards, NT
I
Ian Stirling
I'm guessing (not looked at link) that they are talking about carbon fiber.
"Carbon Fiber Electrode" ?
There are various sellers selling raw carbon fiber on ebay, for little money.
Gary Lecomte
ionizer as shown."
TIA
One or two needles is quite satisfactory.
Ideal voltages are between 4,500 to 5,000 volts.
Voltages greater than 5000 volts creates large amounts of OZONE. This
can be Very Dangerous!
Take care..........Gary
K
KILOWATT
Thanks to all of you for the replies...was appreciated. Yesterday i've
bought a ready-made air purifier based on negative ions technology. It's not
that i'm too lazy to build one myself, but i couldn't resist when i saw it.
I was shopping for a humidifier and went out of the store not only with a
humidifier but with this ionizer! Was all air quality-related expenses,
finally :)
http://www3.sympatico.ca/kilo.watt/images/ionizer.jpg
I've saw the product a few years ago on TV and believe me, after 36hours of
operation, let me say that it works! The surrounding collector band is
positively charged to attract the dust that have been negatively charged
with the negative ions (from three needle that acts as the emitters...they
didn't used CFE emitters like on the website you've seen on the link in my
previous post). It collected a lot of dust already wich seems promising.
Ian...you're probably right about the defenition of "CFE". Even if they
don't specify the material, they state: "The long-life CFE ion emitter used
in this model is made from a high-tech, space-age material that is virtually
maintenance-free." Theese days, when we speak about space age material,
carbon fiber is often mentioned. I don't know the voltages used for the one
i've bought, but it produce very little ozone...only a slight odour is
noticeable whithin a feet from the unit.
If the unit still continue to work correctly in a few days, i think that i
will sneak inside to check the circuitry. I don't have a high voltage probe,
but they probably use the inexpensive and common diodes/capacitors voltage
multiplier method. By measuring the 1st stage's voltage(wich is under 1000V
most of the time) and checking the number of diodes used, i'll be able to
estimate the output voltages, both for the positive (collector band) and the
negative (ions emitting points). Thanks again...i'll keep in touch within
this thread.
Montréal Québec
