Audio Amplifier in Common Emitter Configuration
TheLukeMan92
Jan 5, 2023
I need to build an audio amplifier based on common emitter configuration with a BC547 NPN Transistor. The input signal is an audio jack. An 8 ohm speaker is connected as output. Biasing of transistor to be done with a battery of 9 volts.
crutschow
May 7, 2021
987
Why does that amp need to be that design, as it as it is very inefficient and will not generate much power into an 8 ohm speaker?
crutschow
May 7, 2021
987
Any limits on how long the battery should last?
Any other design requirements?
