Entering square bracket in text
14,317
How do I enter square brackets within the text body of a post? It seems the forum software tries to interpret these brackets as formatting commands and deletes the if it can't evaluate them in a meaningful way.
What I want to type is e.g.
Code:
array[i]
My current circumvention is using a code box as above. I'm sure there is a more elegant way, but which one?
Ian
Administrator
Aug 23, 2006
1,486
Unfortunately, the [ i ] tag is the BBCode for italics, so I don't think there's way to use it within a post, unless it's in a code box or has additional spacing to break the tag.
I've been testing out the next version of XenForo and they have an "inline" code option (and there's a plugin for this version to do the same). This means that you can insert code snippets within the body of text. Here's an example image I found on their forum:
Would that be a useful workaround? I don't think it's something I could fix entirely, but adding inline code options may help. If it's not much different to using the existing code tags, I'll leave it be - but I'm happy to add it if it's useful.
Ian
Administrator
Aug 23, 2006
1,486
Excellent :D. I've installed this now.
Here is is in action if you want to use the [i] string in a post :).
You just need to wrap the inline code with the [ICODE] tags. I'll see if I can add it to the WYSIWYG editor.
14,317
[ and { and / and ]}\
Really nice, thanks Ian.
Ian
Administrator
Aug 23, 2006
1,486
No problem! Glad that we've got a quick fix in place :)
I'm having problems adding the code in to the editor, but I'll persist and see if I can get it in to the "insert..." menu. If I can't get it there, then it may need to be used manually for the moment (until we upgrade to XF2 in the future).
Ian
Administrator
Aug 23, 2006
1,486
I should also mention that square brackets should normally work (i.e. [ and { and / and ]), but they'll disappear when using one of the tags listed on this page:
https://www.electronicspoint.com/help/bb-codes
[i] [b] [u] will probably be the most common ones, especially "i" in programming related posts. It's a shame that the forum software doesn't invoke them only when there's a matching closing bracket, as that would avoid the problem.
14,317
The software seems to be better than you think: it amends the "missing" closing brackets ;)
  • Like
Reactions: Ian
What's the problem with array[i]?
Ian
Administrator
Aug 23, 2006
1,486
I had to view your post to see how you did that! A very clever workaround using invisible [size=3] tags within the brackets to break the auto parsing :D.
You're giving away all my secrets :)
Another way is if you set up the censoring to change \[ into [ and \] into ].
I actually had tried these escape sequences before posting.
Yeah, they're not implemented here, but there is a way in the software to do it.
The "censoring" allows the operator of the software to provide a list of words and what they will be rendered as.
You might have "shit" become "****", to limit the effect of poor use of language. It's actually pretty ineffective at that because people will always come up with a way to say s.h.i.t, s#it, sh1t, etc., but it is useful for other things. I'm not certain, but it may be used to transform :-) into :).
It does the change on the fly, after any markup has been performed, so the transformation itself can't generate tags.
Censoring /[ to [ this doesn't actually change the text, but it does change what you see. It's not an escape as such because there \ isn't a general "take what follows as literal" operator.
Well spotted!
array[i]
That works too, great.
[bold][plain]array[i][/plain][/bold]
Ian
Administrator
Aug 23, 2006
1,486
Browsing through EP's list of BB codes, the PLAIN tag may also work.
As in this online test..
Then enter inline[i]
Oh boy, do I feel silly - the ability has been there all along! I even had a good search of the developer forums to see how to do this :eek:. Well, I've certainly learned something today :D. Good catch @FuZZ1L0G1C!
Tha fios agaibh
Aug 11, 2014
2,253
±μΩ I have a dumb question to ask.
How do you enter the characters ±μΩ on the fly while typing?
When I try to enter them they always pop up at the beginning like this (see first 3 characters).
Ian
Administrator
Aug 23, 2006
1,486
It should normally enter them where the cursor is (here's my test in Chrome on Windows 10: Ωμ±). If it's not doing that, I think it may be down to the browser - could you please let me know what you are using (and OS) and I'll see if I can replicate it and get it working :).
14,317
I want to see them here: ±Ωμ - Works like a charm in Chrome under Windows 7 - µ even via keyboard (no need to access the icon, but need icons for Ω and ±).
