Fault with speaker aux output - goes away with power cycle, then comes back
JMUDoc
Sep 7, 2021
I have a set of PC speakers with aux in and out. I plugged my headphones into the aux out and heard loads of crackle and bass blowout. I took the main unit (the other is a slave) apart and had a look at the aux daughter board, but couldn't find anything wrong, so I put everything back together and tried the aux out again, and it worked. Yay!
However, within a couple of minutes the fault had come back. It does not affect the main speaker output, only the aux, and a power cycle always clears it for a minute or so, but then it returns.
Any ideas on what could be wrong, based on this description?
Thanks in advance.
14,317
That could be a faulty solder joint, temporarily fixed by your manipulating the boards. Visually inspect the solder joints, re-solder any that look suspicious.
When you do a power cycle, do you leave the speakers off to cool down or do you immediately turn them on again? If the latter, a thermal effect is unlikely. Otherwise operate the speakers while open and look for any components that get unreasonably hot.
JMUDoc
Sep 7, 2021
The power cycle fixes the problem immediately - literally off-on, and it's back to normal.
I'm sure my board messing didn't do anything; it was the power cycle that I had to do to get access to the board!
