function to send data
vead
Nov 27, 2011
473
Hello
I need help to understand this function. This function is use to send 8 bit serial data (8051 MCU, embedded c, I2C)
Code:
unsigned char I2CSend(unsigned char Data)
     unsigned char i, ack_bit;
     for (i = 0; i < 8; i++) {
        if ((Data & 0x80) == 0)
            SDA = 0;
        else
            SDA = 1;
        SCL = 1;
         SCL = 0;
        Data<<=1;
     SDA = 1;
     SCL = 1;
     ack_bit = SDA;
     SCL = 0;
     return ack_bit;
what is meaning of this line if ((Data & 0x80) == 0) ?
Rixen
Feb 16, 2016
98
If ((the result from the first paranthesis) is 0))
Do stuff
Did you even try say, Wiki? I did and it's in the first few lines.
Rixen
Feb 16, 2016
98
I didn't understand what is the 0x80. is it address of low bit?
Not sure I understand, but..
0x80 translates to '1000 0000' in binary, because the eigth(0-7 from right to left) position has the weight of 128..
This is the most significant bit. (or sign bit)
vead
Nov 27, 2011
473
0x80 = HEX80 = decimal 128
trying to understand what the meaning of this condition if ((Data & 0x80) == 0)
This is the bitwise & operator. It does an and-operation of these two Data , 0x80
Code:
bit7 bit6 bit5 bit4  bit3 bit2 bit1 bit0
 x     x   x     x     x   x    x   x
x mean 0 or 1 digit
Data = xxxx xxxx;
0x80 = 1000 0000;
          = xxxx xxxx
I am confused on 0x80. it could be anything like 0x60 or 0x55. why there is only 0x80. any specific reason?
