G8P-UA-006203 REPLACEMENT
MRGREENEGG
Jun 22, 2023
This relay is no longer available. Was told by someone whom I do no trust that relay T9AS1D12-15 is compatible. I would hate to operate on this oven control board which is NLA and it not be right. Thanks for any guidance.
kellys_eye
Jun 25, 2010
6,512
15V coil and 30A contacts? Dunno - what is the actual spec? If you can't get an identical replacement then soldering wires from the board to contacts on the next suitable alternative relay is the only way to go.
The relay you were 'told' is compatible actually IS compatible so go back and apologise to the person you 'don't trust'.....
