Ground plane slit?
I have an analog circuit (A-D and filter) that has to get placed
relatively close to an FPGA (0.3" between the nearest points on the
FPGA to the closest component of the filter, generally about 1" for
most parts). I'm concerned about picking up any noise from the digital
stuff. My intuition tells me that (in the absence of a proper split
plane, which isn't doable in this case) it would be useful to put a
slit in the ground planes between the filter and the fpga.
Any opinions? Alternatives (can't move either block)?
Chris
MooseFET
I you are doing an FPGA, it is likely that you have many layers in the
board. This can let you put an extra ground plane in the board under
the analog on the comp-side buried trace layer.
Something like this
Analog Digital
Comp copper Comp copper
Analog Ground Traces
Ground Ground
Analog power traces
Analog ground traces
Vcc Vcc
analog ground traces
solder copper solder copper
Something like this
Analog                Digital
Ground                Ground
Analog power          traces
Vcc                   Vcc
- Show quoted text -
to the OP
read all of HJ's books on black magic...the answer is in there..
Mark
