Hall-effect vehicle ignition system
Barney
I am having problems with an old (H reg) Vauxhall Cavalier. Basically it
won't start - there is no spark. These have a fairly basic electronic
ignition system which consists of a hall-effect unit in the distributor, an
electronics control module, a darlington power transistor amplifier and a
coil. What I need to check first of all is if there is any output from the
hall-effect unit, but I have no means of doing this. Anyone got any ideas
about signal levels coming out of this, etc, or any other ideas about checks
I can make without much in the way of test equipment?
default
I have a hall effect pickup on my truck's speedometer. It is three
wire. Has +5 volts to one terminal, ground on the other and the
middle wire varies from +5 to ground as the rear wheels turn. It is
on the differential. Identical device on the drive shaft (anti-skid
input?)
Barney
input?)
Yes this is three wire too, but with a 12 volt supply - I think they usually
have a voltage regulator, so that the supply voltage can be anything from
about +3 volts to +24 volts. If the output is roughly a square wave from 0
to +5 volts I should be able make a simple tester for it quite easily.
Many thanks.
default
Nice thing about it is you can slowly turn the engine and watch it
turn on and off with a meter or use a magnet . . .
No reason it can't be a 12 volt switch. My truck is old and the speed
sensor just goes into the "computer" which probably has a 5V regulator
built in.
Barney
That's an excellent idea. I don't need any kind of a tester - I can just
take out the spark plugs, and then use your method of turning the engine
over slowly and measuring the output with a meter.
Cheers.
