PWM hall effect throttle problem
maker_f7qflnb8_1663278496
Sep 15, 2022
4
Hiya.
Hoping someone can give me some advice. I have swapped a potentiometer on a pwm controller with a hall effect throttle pedal on a kids electric car build (I flipped the magnet in the pedal so it outputs the way the pwm is expecting)
The problem I am having is that the minimum output the throttle gives is 0.8v which makes the motor run at 17% load constantly, as opposed to the pot which can go all the way to 0v. I can't think of a simple way to reduce the voltage at zero throttle, but maintain the full voltage at full throttle (as this is already only 4.2v max, as opposed to the pots 5v max).
danadak
Feb 19, 2021
1,072
Send output/signal thru a silicon diode, depending on current that will drop
V by .7 or more.
Regards, Dana.
You'll more than likely have to feed the signal through a rail to rail op amp amplifier.
Sep 15, 2022
4
Thankyou. I considered a diode but that would drop the voltage of the max throttle too. Can a diode survive breakdown voltage over and over again? I.e. if I insert it into the circuit backwards it would resist the initial 0.7v but when throttle is applied it would give up and allow the full voltage through?
I'll look into op amps now
Alec_t
Jul 7, 2015
3,817
If you presently have 0.8V to 4.2V but want 0V to 5V then you need a rail-to-rail op-amp as Bluejets mentioned. Just using a diode won't do what you want.
crutschow
May 7, 2021
986
That's because there likely is none.
Below is the LTspice simulation of a basic differential op amp circuit that should do what you want.
It generates a 0 to 5V output for a 0.8V to 4.2V input.
The op amp must be a rail-rail type (inputs and outputs can go from ground to the plus supply).
The simulation shows the output (yellow trace) going from 0V to 5V for an input (green trace) of 0.8V to 4.2V.
The circuit uses a 5V supply.
The comments show how the calculations are done for a desired negative offset (0.8V here) and circuit gain (5 / 3.4 = 1.47 here).
Sep 15, 2022
4
This will help calculate the necessary gains and offsets needed for OpAmp solution :
Regards, Dana.
Thankyou Dana for t. There's a lot to digest there for me, my electronics education stopped at age 13! I'll see what I can do.
Thankyou that's a big help
Another option is to use say, an ATtiny85 and map the new input to your required output level.
