Help finding right cable/connector
jack12345
Jun 3, 2014
So I have a DT70H-16-26PN (http://detoronics.com/pdf/Technical_Specs_DT.pdf) circular connector in place as a feedthrough in a vacuum system, and I need to find a connector/ cable to connect to that. The part on the inside of the vacuum is solder cups, and the outside is pins (26). I need something to connect to that to break out into wires.
shrtrnd
Jan 15, 2010
3,902
What am I missing? Are you just asking for a mating connector for the Detoronics connector?
Can't the manufacturer recommend the mating connector that you need? (Or have a website spec sheet that does it?).
Or am I misunderstanding your question?
