root
- Jan 1, 1970
- 0
I got a used computer on Saturday at a yard sale. I bought
it for the case, although it came with a motherboard and power supply
but no drives or video card.
I put a video card into the machine, along with an IDE drive
and the system ran fine.
I replaced the motherboard with one known to be good: I pulled
it from a working computer. I wanted to be able to use SATA
drives in the "new" case. The power supply did not have any
SATA power cables so I used the molex-sata power adapter cables.
When I turned the system on with the first SATA drive in
the system a component on the drive smoked and the
drive is dead. The component is a surface mount plastic
two-terminal (I think) device about 1/8 x 3/16 inch.
I can just barely read C651 on the device.
I swapped out the power supply for a second unit,
and put in another SATA drive. I checked voltage to the
molex and it was 11.86 volts and 5.09 volts.
It happened again, when I turned on the power I killed
the second SATA drive.
I took my motherboard out of the new case and put it
back in the my old case. Everything runs fine.
I put another power supply in the "new" case, this
power supply did have SATA power cables. Back into
the case went my motherboard. Again, upon power up
a third SATA drive was blown. The SATA cables coming
from the power supply had an extra orange wire that
the molex adapter cables do not have.
Three SATA drives down the drain. IDE drives work
fine.
The last drive that burned up had only the SATA
power cable connected. That means the motherboard
is out of the picture.
I have run out of expendable SATA drives. Any idea of
what might be the problem?
fine.
