Help me wire up my small 110AC case fan, schematic included
sea
Mar 28, 2012
30
I want to hook this up for continuous use, I will just unplug when needed, I want to hook to 110 AC
There is one of each color wire, Red, Blue, Black, Yellow ... as pictured below
Thanks for any help
Nehmo
Oct 15, 2011
7
The fan motor is designed to run on either 110V or 220V. Use the schematic on the left for 110V. Use wire nuts large enough for 3 wires.
The incoming line has 2 wires.
Connect the Brown & Blue to one line wire.
Connect the Red & Black to the other.
14,487
note there is no brown !!
one would assume that the yellow is the brown
@sea -- check for continuity between black and yellow .... should see some resistance of the coil
Nehmo
Oct 15, 2011
7
I assumed the brown in the schematic is what looks yellow in the pic. IOW,
brown = yellow.
It's easy enough to check, as Davenn suggested,
It's possible the camera or lighting is a factor, but it more likely is an incorrect label. This wire-color mismatching between the label or schematic and the real product is common. It could have happened if the factory preprinted plenty of labels but ran out of brown colored wire. The assembelers would then use whatever wire they had on hand but still use the already-printed labels. They would hope if anybody needed to know the proper colors, it would be someone capable of figuering out their switch.
