Help to modify push button (reed switch) power circuit
arjfca
Sep 12, 2013
4
I want to have a circuit that will be activated on / off using a magnet over a read switch. This switch to be use ito power the receiver and servo in a radio controlled sailboat.
The original design came from this site
This actual circuit do power on, but the power off is intermittent. The original circuit was using a NPN transitor, but I modify it to use an N-mosfet to reduce power usage from the battery.
Any suggestion on modification to be apply on parts values or redesigning the circuit. The Vbat is from a LeFePo battery at 6.6V. I'm using a 2.2K hooked to Pout to simulate a charge
Any suggestion appreciated
Martin.
P.S. 1-excuse my English, more fluent in French
P.S 2 I did study electronic, but it was more than 40 years ago. My knowledge is a bit rusted
14,317
The base current to the original NPN is limited by R6 and therefore is probably neglible compared to the current through the load (2.2 k in your case). Therefore a NPN can be used easily.
What is the type of NMOS you use? Are you aware that you need an NMOS with a very low Vth? Often called "logic level" MOSFET.
arjfca
Sep 12, 2013
4
Hello Harald.
The N-Mosfet is 2N7000
No i was not aware about the logicg mosfet. I will look for that. Never worked with mosfet before.
Martin
We used very similar arrangement on RC aircraft.
Operation was, magnet in .....(in a brass tube with a red cloth marker)....switch off.
That way one couldn't loose the magnet in flight and have it switching off.
Below is the circuit we used and the pcb layout.
Note:- in the schematic below, the hall effect I did not have a symbol for, hence replaced with an opto isolator symbol.
It is a hall effect, possibly one of the later model one gets on the Arduino modules these days would be better.
KY-003......either way it's a connection to the 3 terminals on the pcb.
Module operation indicator is of no concern i.e. power draw as one only plugs in the supply battery before flight/sail.
Just watch orintation of the connections on the module.
