Help with a PIC12F1571-I/SN?
chopnhack
Apr 28, 2014
1,576
I am looking for a model of this IC for use in Eagle. Does anyone have a resource on it?
PIC12F1571-I/SN
Thanks.
14,293
What do you mean by "model"? Simulate? Then you'll need a model for your simulator. Eagle doesn't simulate as far as I know.
14,480
Agree with Harald
if you want to model/simulate your circuit then you will need something like LT Spice
14,480
there is a new piece of software ... PCBSim by Felicitas Customized Engineering that interfaces with Eagle CAD
14,293
I didn't know that. Assuming this is what chopnhack means, one can still use a dummy package in Eagle and replace it by the correct model in the netlist for simulation - provided there is a model for the respective processor in the simulation software.
From reading the above, my naive suggestion is to contact the supplier of the simulation software and ask them.
chopnhack
Apr 28, 2014
1,576
Thank you all, I didn't realize the Eagle software was solely for PCB production. I only recently downloaded it and started working with it. I also have LTSpice and started modeling the circuit there, but was referred to Eagle for PCB layout. From what I understand, LTSpice can do the layout too via a netlist export function. From toying around with it, Eagle looks like it produces a more accurate PCB layout. :)
14,293
The recent version of Eagle can export to LTSPICE for simulation.
However, any SPICE based simulator is primarily for analog simulation. YOu will not find a SPICE model for a PIC processor.
