Help with Amica WiFi board circuit
Status
Not open for further replies.
CircuitMaster
Dec 17, 2016
48
Good day! On this circuit can someone bring a little clarity, because searching in google does not help.
I have an Amica WiFi board that needs 3.3v to run and a voltage level shifter. They are both made in KiCad, but on the circuit for the shifter it has 1npn and 1pnp transistor, but the name of the second transistor is the same as the first. So there is a mistake. Can anyone tell me how this circuit works please, as its confusing to me.
[Images removed by moderator on request]
This is for a company.
Alec_t
Jul 7, 2015
3,820
:confused: I can see only two MOSFETs.
The IRF7351 is an N-channel type, so Q1A is correct. Q1B shows a P-channel type, so it can't be an IRF7351 if indeed it is meant to be a P type.
CircuitMaster
Dec 17, 2016
48
I don't know what its ment to be. That's why I ask does anyone know a anything about this circuit? And about the Amica WiFi module (NodeMCU) as I can't find a valid data sheet.
Note the pin numbers. I suggest that when I Google that part number I'll find its a dual mosfet in an 8 pin package.
Edit: yup. Just Google it.
CircuitMaster
Dec 17, 2016
48
Google it didnt work. That's why I posted here. But its OK, I already solved the problem.
Status
