Help with diagnosing problem with pcb from charge controller
sandtaz
May 19, 2014
38
The board on the charge controller for my wind generator is not working, possibly from power surge from generator or batteries. Replacement board is not available (company went out of business). Is it possible for me to test the components on the board with just a DMM or should I try and find someone who can do it for me? Sure could use some help/guidance. Thanks.
14,487
Hi
welcome to the forums :)
Its possible you may be able to do some testing :)
we need lots more info first, tho
how about some sharp and well lit pics of the circuit board, both sides
maybe do some annotations to show where the interconnecting wires to and from the board go to.
cheers
sandtaz
May 19, 2014
38
Here is a picture of the board contained in the instructions for the controller. The three large lugs on the left are dc input from the generator. Two wires upper left are to the dump load. White connector upper right go to the dump load switch and the led indicator lamps. At the bottom, just off picture, are the battery connections. Hope the picture is ok. Tks for your help. Tom.
Hi
cheers
14,487
hi :)
not really close enough for us to determine any faulty components
can you please take photos of both sides of the board sharp and well lit
close enough that we can see markings on components
cheers
sandtaz
May 19, 2014
38
hi :)
cheers
Here are a bunch of close-ups. Thanks for trying to help. Tom.
hi :)
cheers
sandtaz
May 19, 2014
38
Has anyone had a chance to look at all the pic's I posted? Are there too many; not enough; not clear/close enough; would more info help? Really appreciate the help. Tom.
D7 in your second image looks like it has had mechanical damage (was it hit by a nut or a spanner?). Check that.
I would also check the 6 TO-220 devices that are under the heatsinks. As the connections are exposed, you can test to see that they aren't shorted without removing the heatsinks.
You may have to remove the heatsinks to see the part numbers though.
Also, don't use a flash, it causes lots of specular highlights that can hide things.
sandtaz
May 19, 2014
38
Steve, thanks for your response. Let me give everyone a little more detail. This is a charge controller for a wind generator. The ac from the generator is converted into dc current and enters the controller via the three connectors on the left side of the board. The controlled dc current leaves via the two large lugs on the silver colored bars at the bottom. The problem occurred when I was changing out my batteries. Instruction were to disconnect at least two of the three leads from the generator before disconnecting the batteries. I believe that one of the two wires remained touching the connecting point. When I disconnected the batteries I believe that uncontrolled voltage entered the board from the generator. D7 is in the area where the voltage would have come in. As far as I can remember, no damage was done to D7. I used my multimeter (only electronic testing tool I have) to check for continuity with negative results. I do not know how to check D7 further. I am not sure what you mean by "the 6 TO-220 devices under the heatsinks." Thanks again for your help. Tom.
Picture 1 shows the heads of 6 bolts. Between them are drawn the shape of 4 transistors that will be visible once you remove the screws and the metal covering them. There is likely to be some white or grey paste on the devices and the metal to help transfer heat.
These devices are the ones which switch the power and are also the ones likely to have been damaged. Once you expose them you should ge able to read the part numbers from them. This will allow us to tell you how to test them.
TO-220 is the name of the package. The drawing on the top side of the board is of such a device. (It's as descriptive as saying a car is a sedan or hatchback. It tells you something about the shape of the car, but nothing much else).
As for D7, if you have a diode test range on your meter, with the leads one way around you should get a low reading (perhaps 0.2 to 0.7) and a much larger value with the leads the other way around. If you don't have a diode range, then a resistance range should give a much lower reading in one direction as opposed to the other. Tell us what range you used and the readings you get.
sandtaz
May 19, 2014
38
Thanks for walking me through that. The number(s) on the back of the transistor is JRFB4410 and under that is 641P. Letters on bottom are PC and QB.
Multimeter does not have diode tester. With scale set at 200k, a reading of =
40 with positive on the left and a reading of 86 on the right. Only looked =
at one transistor, will all four be the same? After 11:00 pm here, guess it=
is time to call it a night. Thanks again for trying to help a technology c=
hallenged person. Tom.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
www.irf.com/product-info/datasheets/data/irfs4410.pdf
N-channel MOSFET; 100V, 96A. RDS(on) typically 8 milliohms; maximum 10 milliohms, at VGS=10V.
Applications:
  • High Efficiency Synchronous Rectification in SMPS
  • Uninterruptible Power Supply
  • High Speed Power Switching
  • Hard Switched and High Frequency Circuits
Are they all the same?
There's probably not much point checking them individually while they're in-circuit since they'll probably be in paralled groups.
sandtaz
May 19, 2014
38
Applications:
Thanks for the info. If they are in parallel and attached to the board, is there a test that I could do to determine if all are good or if one or all are bad? Limited test equipment and knowledge. Thanks. Tom.
KrisBlueNZ
Nov 28, 2011
8,393
Upload a photo showing all six of them with the metal bits removed. I will mark up the photo to show you where to measure with your multimeter.
sandtaz
May 19, 2014
38
I only see four. Could you elaborate on "the metal bits removed." Thanks.
KrisBlueNZ
Nov 28, 2011
8,393
Sorry, you're right. There are only four.
You've told us the markings on one of them. It's likely that they're all the same, but not certain. Can you check the others please.
While you have the heatsinks removed, can you take a few photos of what's underneath them (i.e. between the heatsink(s) and the board).
Can you take a photo of the whole board, rotated so it best fits the camera frame. Please read the guidelines at https://www.electronicspoint.com/resources/how-to-take-photos-of-circuit-boards.6/
Please add text to the board identifying the major connection points and listing all the markings on any component with three or more leads.
sandtaz
May 19, 2014
38
That's excellent and it confirms the parts are all in parallel. That also pretty much confirms that they will be the same part number.
Note that each has its own gate driver. (also good).
Take note of this image:
Use your multimeter on the diode test range or a low ohms range to check the resistance between the top two pins. Then swap the multimeter leads over again and get a second reading.
You only need to do this for one device because they're all connected together. The pin NOT involved at present is the one with the small track leading from it to other components.
Tell us the rang you used on your meter and the readings you obtained.
Oh, and was there any heatsink compound on the heatsinks when you removed them?
sandtaz
May 19, 2014
38
Meter was on 200 and with red lead on top reading of 90.2. When leads were reversed no reading. Did the same test on the one above with same results. Must be clear coating on pcb, had to scrape the joints a little. There was/is no compound but there is a red gasket type material under the center screw and plastic spacers on the others. The pictures were a mistake. Was trying to figure out how to put text on a picture when I pushed wrong button. Sorry bout that. Thanks Tom.
Presumably "no reading" means "OL". If so, that's great. There is a diode across the drain and source and you have detected that. This means that none of the mosfets are shorted between drain and source (a common failure mode).
Kris did suggest you check the other mosfets for their part numbers, so perhaps you should :)
sandtaz
May 19, 2014
38
All four have the same number. Thanks. Tom
