Help with IR motion sensor
slackjack
Nov 2, 2005
177
I'm trying to buld this
Left = transmitter
Right = receiver
This circuit has a transmitter and a receiver. So from what I understand, the interruption in a modulated pulsating beam that is transmitted by an infrared diode and received by an infrared transistor sets off the alarm. So what I am looking at is two different circuits. Can't these two be integrated into one circuit?
So I absolutely must have the circuit with the Photodiode right? If they cant be integrated, how must the receiver be placed with respect to the transmitter?
What are some uses of a Phototransistor?
--thank you 8)
ante1
Jan 24, 2004
4,138
Hi jack,
What would be the point of integrating the two circuits? What would you use it for then?
audioguru2
Apr 6, 2004
12,026
If the circuits were integrated side-by-side and pointing in the same direction then they could be beaming and receiving the IR from a mirror on the other side of a corridor to be monitored. An intrusion would break the beam and signal the alarm.
If the intruder had his own mirror or modulated IR beam then he could easily not be detected. ;D
stevedabear
Jul 12, 2005
30
What confuses me about this system, is that ii cant see that it would stay on once it has been tripped... Surely it would be best fed into a locking transistor ? with a reset... just a thought.
audioguru2
Apr 6, 2004
12,026
That's correct. The circuit doesn't have a latch on its output so it could be used to count cars driving by or somethin'.
slackjack
Nov 2, 2005
177
Ante said:
Hi jack,
I was just asking if its possible. Mayb it would just be easier to build one circuit instead of two...or did I miss something.
slackjack
Nov 2, 2005
177
So without the latch, the output would not remain high when its activated right? What kind of latch do you recommend. Probably a NOR latch?
audioguru2
Apr 6, 2004
12,026
Correct. Make a latch with a pair of cross-coupled NOR gates. Consider using power-up reset and a manual reset. ;D
Shahriar
Mar 18, 2004
451
You can Also creat a latch with D-Filp Flops. 7475. (Check it!)
Anyway, there is a project in the Project section of this site. Its name is Park-Aid. Take a look. It will anserw to some of your questions.
HTH - Shahriar
slackjack
Nov 2, 2005
177
Thanks for the link Shahriar. It seems they have integrated the emitter and receiver circuits.
D2 picks-up the infra-red beam generated by D1 and reflected by the surface placed in front of it.
All what this circuit does is detect an object as it moves toward it, in this case the car right? If thats so, then this circuit would do just fine for experimental purposes. A vehicle is relatively wide though. Would it detect a person just as good as the car?
audioguru2
Apr 6, 2004
12,026
The Park-Aid circuit detects the strength (which is also its distance) of the IR beam reflected from a mirror (or white paint) on the wall. If something blocks the beam then its output indicates it as no received reflected IR signal. It would easily detect a person.
