Help with Thermistor
dontpresstheredbutton
Feb 10, 2022
4
Hi guys, I don't know much about circuit boards so I'm wondering if someone can identify & tell me if there is a Thermistor on this board which is on a printhead from Epson. I'll provide a pic but otherwise these Epson part codes may give you a better look on a image search.
F05505 F055090 F055050 F055030 Epson DX2
Any help will be appreciated.
14,486
I dont see a thermistor on that board
Dont you have a larger photo to make ID easier ?
Alec_t
Jul 7, 2015
3,821
Why do you think there's a thermistor on any of those particular printheads?
Feb 10, 2022
4
The printheads go in the Roland CJ_500 large format printer. It was working fine then I took one of the heads out to clean it. When I put it back in and turned on, I got an error code saying the machine was to cold to operate. When I looked online the only information I could find was a small part of the maintenance manual that says the temperature or Thermistor is read on the Printhead.
Alec_t
Jul 7, 2015
3,821
I would expect any visible thermistor to be a non-descript surface-mount device (SMD) component (such as this example), visually similar to a SMD capacitor or resistor. It might even be an internal component in a multi-pinned IC. However, thermistors are generally very reliable and my guess is that the problem is more likely due to a faulty re-connection between the printhead and the machine.
14,312
Is there anyway of finding a schematic for the printhead?
Considering the policy of printer manufacturers with respect to protection against cheap knock-offs: very unlikely.
Does it state "temperature" or does it state explicitly "thermistor"?
Temperature can be measured in manifold ways, even by the ´voltage across a diode or a bipolar transistor's B-E leg. Modern temperature sensors often come as integrated circuits with a digital interface.
Have you tried to remove it, clean all contacts and reinstall it? make sure the printhead is seated firmly in the printer.
